4th gen rear end swap ?
Old Sep 5, 2007 | 02:54 PM
n8sz28's Avatar
Car: 85 camaro z28
Transmission: T56 6 speed
Axle/Gears: 3.27 borg warner 9 bolt
did any of the 4th gen rear ends come with a 3.73 rear end or are they all 2.73 3.23 and 3.42? and are they all posi. i'm looking at one that says it's from a 98 firebird that is a NON LOCKER and has a 3.73. i thought they didn't have a 3.73 stock. and what do they mean by a non locker- does this mean it doesn't have posi traction.
Old Sep 5, 2007 | 03:05 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 4th gen rear end swap ?
i never heard of any 4th gens getting posi and 3.73's. now V6 cars i have no idea..it is posible i guess that a v6 car got 3.73's but it would be an open diff and not posi
Old Sep 5, 2007 | 03:11 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Stock gears in all of the 4th gens are these: 2.73, 3.23, 3.42
Early V6 cars had 3.42 non-posi, late V6 had 3.23 non-posi (posi may have been an option)
Old Sep 7, 2007 | 12:12 PM
n8sz28's Avatar
Car: 85 camaro z28
so the v6 rear ends weren't posi are all of the lt1 and ls1 rear ends POSI?
Old Sep 7, 2007 | 11:49 PM
Zepher's Avatar
No, posi was optional on the LS1 and LT1 cars, some models, like the WS6 and SS's had posi stock.
Old Sep 11, 2007 | 04:02 PM
n8sz28's Avatar
Car: 85 camaro z28
what i don't understand is that in a 3rd gen when you have a limited slip differential it usually spun 1 wheel. and in the 4th gen camaro and firebirds the limited slip usually spins 2 wheels at least my brother does. whats the difference
Old Sep 11, 2007 | 09:09 PM
n8sz28's Avatar
Car: 85 camaro z28
i think my car has an open differential and everyone just calls it limited slip because it slips!!
when i lift my car up and turn one wheel one way the other will go in the opposite direction.
my brothers 93 trans am both wheels go in the same direction.
this brings up the question again does all 93 -02 firebirds and camaros have limited slip also known as posi tracion?
Old Sep 11, 2007 | 10:16 PM
Zepher's Avatar
Posi = Limited Slip and both wheels spin the same direction when the rear is in the air.
Non-Posi aka Open Differential, one wheel spins the opposite of the other.
Limited slip is an option on the 4th gens.
Now for more confusion, the 98-02's had Torsen Differentials which are a torque based unit. both the Posi and Open diff Torsen units act like open diffs when the rear is lifted off the ground.
Old Sep 12, 2007 | 11:06 AM
n8sz28's Avatar
Car: 85 camaro z28
wow that does make things harder when your looking for a used rear end. now when you say its an option , your saying that not all v8 camaro and firebirds had the limited slip.
Old Sep 12, 2007 | 11:12 AM
n8sz28's Avatar
Car: 85 camaro z28
so what is the easiest way to tell from 98-02 if your getting a posi traction. did some of the v8s from 98-02 have an open diff or did they all have posi?
Old Sep 12, 2007 | 02:51 PM
Keenov's Avatar
Car: 2003 Cobra
Limited slip was standard on all 98-02 V8s.
If you are pulling it from a 98-02 V6, make sure the donor vehicle has RPO code 'G80' (G80 - Axle Positraction, Limited Slip)
Old Sep 13, 2007 | 06:50 PM
n8sz28's Avatar
Car: 85 camaro z28
is this true that all 98-02 camaro s and firebirds w/ a v8 had a limited slip?
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
