narrowed 9"
Old Jul 7, 2005 | 05:54 PM
91bluemetalicRS's Avatar
narrowed 9"
i have come across a narrowed 9 inch rear, does anyone know how narrow you can go before you have to tub?
current 10 bolt measures 55 inces from backing plate to backing plate. 9" measures 47 inches from backing plate to backing plate. I am getting this for next to nothing and would really like to be able to use it. I measured the furthest end of the spring perches on 10 bolt and it measures 49 inches. Will this also be a problem or can you buy a spring perch kit that is shorter than factory?
Old Jul 7, 2005 | 06:05 PM
Blownpickl's Avatar
Car: 57 Chevy not an F Body
Engine: Twin Turbo 350
Transmission: Doug Nash 5 SPEED
Axle/Gears: 12Bolt 4.56
oh the irony
Read my post and see what you think of my 9"
Old Jul 7, 2005 | 06:34 PM
oh the irony, check your email
Old Jul 7, 2005 | 07:00 PM
does anyone know how narrow you can go before tubbing?
this of course with stock 16" wheels
Old Jul 7, 2005 | 08:27 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Depends on your wheel backspacing but factory wheels and tires could probably have a diff narrowed about 2" on each side. There's very little room on a third gen between the tires and the frame/inner fender to narrow a diff and shorter than a factory diff. There is no real "tubbing" on a third gen The inner fender is already right at the frame rail, if you could call it that.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
tyeo098
Nov 30, 2015 06:27 PM
Mdenz3
Sep 17, 2015 08:36 AM
ericjon262
Sep 11, 2015 06:07 PM
sylentnite
Sep 9, 2015 02:55 PM
