tranny fluid leak problem?
Old Jul 10, 2005 | 08:31 PM
82knightrider's Avatar
Transmission: TH200C....700R4
Im leaking tranny fluid pretty bad and I dont know where the heck its coming from.My buddy and I took off the plastic shield thingy and its dry in there so its not the front main seal .
The drve shaft is dry and everything around it.So dont think its the rear seal.We also checked all the connections for the trans cooler lines and there all good on the tranny side and the radaiator side,no signs of fluid leaking.Im leaking fluid but dont know from where Can anyone help me diagnose(sp) this problem.thanks
Oh yeah,when I take the S/E for a spin a lot of smoke comes up from under the car on the passenger side near the cat.And it smells like burnt tranny fluid for sure..........
Old Jul 11, 2005 | 01:25 PM
SydwayzTA 86's Avatar
Car: 1986 Trans Am
Engine: 5.7L TPI
Your positive that its tranny fluid and not oil ? what color is it. Also keep in mind while your driving wind blows, so it could be flying onto your cat.
Old Jul 11, 2005 | 06:04 PM
Im positive its not oil.Its tranny fluid for sure.Is it possible one of the tranny cooler lines has a hole in it.Or are those pretty durable They are 20 + years old.........
Old Jul 11, 2005 | 06:12 PM
And it smokes bad when im at a stop.Never see any smoke while driving though......... I l look out all the windows as I drive and still dont see any smoke.
However,when I dive and have the passenger window rolled down I dont see smoke but sure smell burnt tranny fluid and my eyes start to burn.........
Old Jul 11, 2005 | 06:22 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
Did you check the pan? What about the dipstick tube?
Old Jul 11, 2005 | 11:21 PM
Car: 1986 Trans Am
Engine: 5.7L TPI
its possible the lines cracked or has a hole, i suggest cleaning up all around that area, and try to see if you can catch the leak where its starting
btw reply to my pm's
Old Jul 11, 2005 | 11:38 PM
Pan gasket and pan are all good...
where the dip stick tube goes in the tranny,ive been told that its not under high pressure....is there any truth to that.
regardlees...I have the original garment for that bad boy.....
you have a pm dude
Old Jul 12, 2005 | 01:05 AM
Car: 1986 Trans Am
Engine: 5.7L TPI
you have a pm dude
PM Replied
Old Jul 12, 2005 | 03:48 AM
sixpackmtrspts's Avatar
check your torque conveter, i have seem them develop cracks around the welds before.
Old Jul 13, 2005 | 09:15 PM
my1st88camaro's Avatar
Car: 88 Z28 Camaro
Engine: 355 TBI soon to be carb.
Transmission: 700R4 upgraded
Axle/Gears: 4.11 gears
i dont know if you have found the leak or not, or if your TH200C is an automatic or a manual trans (i dont know much about trans, mainly engines) but i have a 700R4 and when i swapped my old one for one that was supposedly in better condition i had to change out the down shift cable. once i got it in i found out the trans was leaking pretty bad. it was leaking at the base of that cable where it bolds onto the trans. i couldnt tell at first cause the fluid would run down all around the edges of the pan and i assumed it was the pan until i wipped all the edges of the pan...then i saw what spot on the edge the fluid was flowing over, then i reached up and felt the area that was wet. it was the base of the down shift cable. plus when i drive it (which i dont anymore until i get it fixed) the fluid would drip onto the exhaust pipe and burn off. it smoked pretty bad at a stop light but once i drove you couldnt see any. so if your TH200C is an automatic then this is a good thing to check for. but if its not then i'm sorry for waisting your time. atleast you know of this situation for future reference
Old Jul 13, 2005 | 10:29 PM
Thats great info man.My car smokes at stop lights like a ****.I have an auto so its a possibility thats the problem.....Im gonna ceck it out....
Old Jul 15, 2005 | 12:23 AM
DeLorean247's Avatar
Car: 1982 Pontiac T/A
Engine: 350 Carb
Transmission: TH200c
That is correct.
Old Jul 15, 2005 | 05:47 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Its not under pressure, but it can come loose. Just throwing out simple suggestions before he has to go to deep.
Old Jul 15, 2005 | 06:10 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
I would check around the crossmember under the engine.. I changed out my tranny and when i put it back in i replaced the lower line. only to find out that the upper line right at the crossmember under the engine has developed a small hole.. which leaked tranny fluid like there was no tommorrow.. and the hole was dinky, not even realy seeable with the eye...
Old Jul 15, 2005 | 11:46 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Clean the whole thing so it's dry. Then look for a leak. Should be easy to spot. If you still can't find it then start the car for a while and look again. Don't drive it cause the wind will blow it around. You should be able to pinpoint it then.
Old Jul 16, 2005 | 01:20 AM
yep. shouldn't take to much effort to find it.. run the car.. the one by the crossmember ran down and then onto the exaust pipe at the bend.. so it if was leaking and you were driving it could very well have traveled to the cat...
Old Jul 16, 2005 | 02:26 PM
Yeah,Im about to fire up the pressure washer and clean under the car.......thanks everyone...ill be back with some updates
Old Sep 1, 2005 | 06:15 PM
Car still leaks tranny fluid.Ive been busy so havnt been able to check it.Im gonna check this weekend.Just wanna keep you guys updated
Old Sep 4, 2005 | 04:47 PM
michta's Avatar
Car: 1984 ta slightly modified
Transmission: auto 350 w/reverse valve body
Axle/Gears: 410 ratio
tranny leak
Also check your cooler line fittings at the trans around the flair on the line. Have found a few that was cracked. If you can support the car from the rear and clean fluid off have friend or someone (i have my wife) inside running through the gears and should see it right away. Good luck and above all be careful.
Thornburg
Aug 25, 2015 01:46 AM
spaigo
Aug 21, 2015 07:46 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
drathaar907
Aug 6, 2015 04:20 PM
