400 sbc what flywheel to bolt up to t5
Car: 1992 25th anniversary camaro
Engine: 406
Transmission: t56
Axle/Gears: 410s
i have a internally balanced 400 sbc and need to know what flywheel i need to bolt it up to my stock t5 cause i don't have the money for the new clutch and tranny yet.
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: 400 sbc what flywheel to bolt up to t5
Car: 83Z28 HO
I think what Apeiron is saying is that pre-'86 engines use the 2 piece rear seal (like mine did). So if you find a pre-86 T-5 flywheel it will fit. Mine did.
Car: `86 SS / `87 SS
400s are not internally balanced unless specifically modified to be so.
An 85 L69 flywheel is fine, but you need an additional balance plate that bolts between the flywheel and crank if it is a "normal" externally balanced 400."
Car: 83Z28 HO
ambainb
Apr 25, 2016 09:21 PM
C409
Sep 23, 2015 04:30 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
