carb on a lockup converter
Old Jul 28, 2005 | 10:56 AM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
will my 700 r4 be okay if it never locks up due to me switching to carb?
Old Jul 28, 2005 | 01:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not if you do much driving in O/D.
Old Jul 28, 2005 | 01:27 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
the worse thing about it not locking up is heat. If you install an external trans cooler, you should be fine. If you are still worried about it, you can get a switch that will control the lockup. I think jegs or summit have them for around $150.
Old Jul 28, 2005 | 01:43 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, and by far the single biggest cause of failure of automatic transmissions is heat.
Old Jul 28, 2005 | 02:21 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I agree.
But I talked to dana at probuilt. I also talked to someother trans builders, and they all said that as long as you run and external cooler along with the stock cooler it would be ok. It wouldnt be a bad idea to install a temp sensor also.
He could also have the trans converted over to non-lockup.
Trust me, I wouldnt give any of this advice if I hadnt thorougly researched the same question.
Old Jul 28, 2005 | 04:24 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I'm not disagreeing with anything you said.
Old Jul 29, 2005 | 09:31 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Didnt try to come across that you were. I guess I thought that I just threw out the info with nothing backing it up. I just get in a hurry trying to help sometimes.
Just thought he would feel better knowing that I had researched the subject.
Old Jul 29, 2005 | 11:58 AM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
k how bout a th 350 converter? or th 400
Old Jul 29, 2005 | 12:03 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
They won't fit a 700R4.
theshackle
Mar 5, 2017 06:37 PM
andy74
Sep 3, 2015 08:41 AM
someone972
Aug 30, 2015 12:52 AM
Eric-86sc
Aug 24, 2015 09:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
