switching from 5 spd to auto---details please?
Old Aug 20, 2005 | 12:30 PM
dennisgramm's Avatar
Car: 1983 Camaro Z28
Engine: 5.0L HO
Transmission: 5speed
Hi, I am considering switching from a 5 spd on my 83 z28 to an auto.=--what is involved, and approx. costs? thanks, Dennis
dennisgramm@verizon.net
Old Aug 20, 2005 | 12:52 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
why in gods name would you want to switch from your 5 spd to a 4 spd auto (if you are going to a 700r4) most go the other way... Pretty much to go reverse you need a new brake pedal assembly, and a new cross member... you would also need the bracket for the TV cable..... also the console shift plate for it.. and also figure out a way to mount the shifter in place (since there is a hole in the floor where the shifter would normall set..)
Old Aug 21, 2005 | 11:25 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
If you want to go fast in the 1/4 mile you go with an Auto and a nice stall.
I went from Auto to 5 speed on my car since I like to be in control.
doing the swap, you will need to wire up the 4pin connector for the Lock-up Solenoid, cover the shifter hole, change pedals if you want to, get a flexplate, get lines for the trans cooler lines, etc...
Makes it easier if you have a donor car that you can get all the parts off of.
Old Aug 21, 2005 | 12:34 PM
eh i dunno.. I can sift it fast enough to where it feels like i am in an auto.. but I get to shift it up higher in the power band and keep power better on the stick..
Old Aug 21, 2005 | 04:34 PM
Zepher's Avatar
doesn't matter how fast you can shift, if you don't know the benefits of an auto and a high stall, then you don't know drag racing.
Old Aug 21, 2005 | 04:37 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
i got a full 700r4 setup that i want to get rid of. ill trade you for the t5 setup.
i got cooling lines, flywheel,transmission, crossmember, b&m hammer shifter, bellhousing, anything you need.
Old Aug 21, 2005 | 04:38 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
oh 700r4 has shift kit, new clutchs, it was just rebuilt.
Old Aug 21, 2005 | 05:18 PM
Tha_Villain's Avatar
Car: Camaro RS
Engine: 2.8 L
Auto might be good for drag but I think standard could still be quicker
Old Aug 21, 2005 | 05:48 PM
Zepher's Avatar
I am not going to argue about it, but do some research on auto vs manual relating to drag racing.
Old Aug 21, 2005 | 06:06 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
Not even worth your time Zepher. Not a whole lot a racers on these forums.
Old Aug 21, 2005 | 09:04 PM
elky74's Avatar
Car: 82 Firebird, 71 LeMans
Engine: GMPP 350, 400 PMD
Transmission: TH-350
I had the same question, only I want to go from a 4 spd manual to a TH-350 for my 4 banger Firebird. I just want it for convenience, plus I think my tranny might be shot. My car is a daily driver that I'll use as a backup to my '04 Hyundai.
Old Aug 21, 2005 | 09:09 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Shoot Brutalform a pm. We did a 700r4 conversion in the spring. He can tell you everything involved. His car runs quicker and also more consistant in the 1/4 mile with the 700 r4
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
Randomtask2
Sep 10, 2015 08:37 AM
luvofjah
Sep 3, 2015 07:08 PM
