Axle interchange?
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Axle interchange?
Will the axles from a 91 Camaro open traction 2.73 go into a IROC 3.23 posi-trac rear end? And if so, how hard is it? Thanks.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Axles don't care what the gear ratio is. The 91 will have 28 spline axles. They will fit into any other 28 spline carrier. 82-89 third gens came with 26 spline axles. 90-92 have 28 spline. Fourth gen are 28 spline but the axles are 2 inches longer and won't fit into a third gen housing.
10 bolt diff axles will not interchange with 9 bolt differentials.
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
actually, 89 was a transition year for the spline count... 26 early in the year, 28 later on in the year
Originally posted by ede
there are two sizes of ten bolts, as you have discovered. to add to the confussion GM changed how they ID the one in 3rd gen f bodys from 7.5 to 7.62, same thing differant name. you have a 7.5/7.62 ten bolt if you have a 3rd gen f body. 89 was transition year from 26 to 28
Car: 1991 RS Camaro
Ok, thanks. I hope it is a late 89 or 90 IROC. I doubt it though. I'm not that lucky. Thanks again.
