10 bolt to 9 bolt/10 bolt noises
Old Sep 12, 2005 | 09:16 PM
maroguy1's Avatar
Car: 85 iroc & 81 sc
Engine: 357 tpi 350 4bbl
Transmission: 700r4/ richmond 4speed
Axle/Gears: 9 bolt 3.45/3.42 8.5"
Question for everyone. 85 Iroc and the 7.5 rear end is making a houling noise when I let off the gas at highway speeds.
So I was thinking of replacing it with a 9 bolt but want to keep my disk brakes. If i can find one without disks and I just unbolt them off the 7.5 and use them on the 9 bolt?? Or if you have any idea what is causing the houling noise let me know also. I know it is a 3.42 posi. Thanks
Old Sep 13, 2005 | 06:28 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'm a bit confused about your question. Ten-bolt and nine-bolt rear discs are swapable, but you'll need the correct backing plates. Check the following link some some info that may help:
https://www.thirdgen.org/techbb2/sho...hreadid=246768
JamesC
Old Mar 4, 2019 | 03:23 PM
Fullmonte77's Avatar
Car: 85 Berlinetta
Axle/Gears: 10 bolt 3.42 with Torsen posi
Re: 10 bolt to 9 bolt/10 bolt noises
Didn't mean to reply to this post. Have no idea how I did.
Old Mar 4, 2019 | 04:56 PM
big gear head's Avatar
Check the pinion nut to see if it's tight. It's a common problem for the pinion nut to back off and cause the noise that you are hearing. This is an easy thing to check. If the nut is tight then you likely have a pinion bearing problem.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
billybob6110
Sep 23, 2015 01:30 PM
GouldyGTR
Sep 7, 2015 09:05 PM
Randomtask2
Sep 7, 2015 05:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
