T-5 Guts
Old Sep 16, 2005 | 02:36 PM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
T-5 Guts
well I got the T5 opened up so I could take a look at things before I put it in sometime this fall
and well, I dunno what im even looking at hardly, the gears all look nice
any common things I can specificially check out?
Old Sep 21, 2005 | 04:30 PM
Liquid_Metal's Avatar
Car: Red '89 GTA
Engine: TPI LB9
What problems have you been having with it? nice pic
Old Sep 21, 2005 | 04:53 PM
dr1's Avatar
dr1
Engine: 305 TBI
nothing yet just picked it up from the junkyard, I figured it would be best to get a look at it before I find out somethings broke after I have it installed
Old Sep 26, 2005 | 03:55 PM
#rdgearslammer's Avatar
Car: 84Z28
Engine: 310
well really just make sure all the bearings are good as well as the syncro also look at the teeth and inbetween the teeth make sure no chips and no scratches NONE the tranny will whin if there is scratches on the teeth that preatty much it.
Old Sep 29, 2005 | 10:03 PM
dr1's Avatar
dr1
Engine: 305 TBI
alright but lets pretend im a dumbass and break it down for me
(we dont always have to pretend on that one)
the gears are supposed to spin independantly of each other right? cos they are on bearings?? if i understand correctly
Old Sep 30, 2005 | 10:34 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
http://www.ttcautomotive.com/English...ice_Manual.pdf
The gears are pressed on to the main shaft and counter shaft. All the things you want to check will be hard to explain to someone that is going to "have it installed". If you can't remove and replace a trans, then you shouldn't pull one apart to inspect it. I'm not trying to be mean, but if you don't have any idea what you're looking at, then its almost impossible to tell you all that you should be checking.
Old Sep 30, 2005 | 12:39 PM
dr1's Avatar
dr1
Engine: 305 TBI
well then thats where i differ from alot of people as i have no problems taking stuff apart and learning something :P
i have a perfectly good 700r4 in the car currently so, its all good.. heh
"have it installed" refers to me and a friend in the driveway, as usual, not a shop :P
thanks for the link!
Old Sep 30, 2005 | 01:18 PM
dr1's Avatar
dr1
Engine: 305 TBI
that pdf seems alot nicer then whats in the service manual, trying to look at the breakdown on that is scary
i dont have it apart I only took the cover off to take a look, couple things i misunderstood
for some reason i thought the gears were supposed to move independantly since they were on bearings but i wasnt really thinking there
i cant really see how reverse works, that actually slides another gear into place with the reverse gear doesnt it?? all i do know is if i slide the lever into reverse and rotate the shaft it slides back out into neutral pretty quick, would that be normal in this case or am I going to be popping out of reverse when its back together and in the car as well?
all the teeth on the (blocker rings?) look good and they slide into gear firmly
PurelyPMD
May 5, 2016 04:57 PM
Zane Story
Oct 8, 2015 12:40 PM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
