How to ID chevy tranny??
Old Sep 19, 2005 | 10:18 AM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
Transmission: 700-r4
I have pics of a th350 (i think?) and wanted to know how to ID them. I want to know what to look at and how to determine if its a usable tranny for a swap into a thirdgen. [I already know about using either the kit to use the 700r TS and the other option of using the long tailshaft to install.] Im more concerned about finding a tranny that can be used on either of those install options.
I have pics of a few connections on this thing. Why would it have an electrical input looking connector??
Anyway here are some pics, all info is appreciated....
Old Sep 19, 2005 | 10:21 AM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
pic2
Old Sep 19, 2005 | 10:22 AM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
Anyway to tell anything about convertors?
Old Sep 19, 2005 | 10:23 AM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
Long tailshaft unit?? 9"
Old Sep 19, 2005 | 11:45 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
the tranny in the pic is a th350 lock-up unit. the bell housing bolt pattern fits a small block or a big block chevy. the electrical connector on the drivers side is the connector for the torque converter lock-up. the switch on the passenger side i don't know what it is. i have not seen one on a th350. the tailshaft should be the long tail shaft. torque converters are usually best if replaced. you can't really tell anything about a tranny without taking them apart. without that it is a crapshoot. lock-up units are heavier than the non lock-up units. the tranny in the pics can be used for the application you want to use it for, but most go with a non lock-up unit for performance applications.
Old Sep 20, 2005 | 11:04 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
this may help
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
z28venezuela
Oct 24, 2015 08:15 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
IROCZ1989
Sep 4, 2015 11:54 AM
