Best Stock Style Clutch??
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
i need advice on what has worked for some and not for others???? thinking of maybe using a spec brand clutch, most likely stage 3. and definetely not a centerforce, thanks
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
I have a spec stage 2. I had a lot of trouble getting it setup correctly, I don't know if it had to do exactly with the clutch but I had pain. After the installs were finished this clutch has hooked pretty well, but I haven't beaten it enough yet with gas prices so high. With your power levels I'd either get a stage 2 or stage 3, but for streetability, I'd say stage 2.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'm unsure why you've discarded CenterForce as a choice. Mine functions great.
JamesC
JamesC
Car: 87 iroc
Engine: 410 sbc
i had on in my 96 cobra that was fine, but the two i have had in my camaro have broken, ie. slung the weights off. i had it replaced by centerforce the first time.
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I had a caenterforce on my 91 back when it was close to stock. Best clutch I have ever felt. Totally happy with it.
But now with my 500 HP 383 and a 12 bolt running through a T-56, I am def running a spec stage 3. If I had more $ I would go with the McLeod twin disk set up. To bad it is over a grand.
The spec 3 is around half that.
Car: 87 iroc
Engine: 410 sbc
well the spec 3 for l98 motors is around 330, less complicated then ls1 clutches...anybody else got opinions??
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
I am running a RAM Powergrip. It chatters some, the pedal is kinda stiff and the engagement is pretty quick, my fiancee has a heck of a time driving it, but when the clutch comes out at 5000rpm with slicks on it gets the job done. This clutch bites as hard as any other manual trans car I have ever been in. It never slips ever, not even the smallest amount. I realize I do not have earth rotating torque like some one here but overall this clutch is doing a good job for me.
novaderrik
Aug 10, 2015 12:44 PM
rsrmoore
Aug 7, 2015 08:44 PM
