Name that part!
Old Sep 22, 2005 | 01:52 AM
DJXero's Avatar
Car: 1992 Camaro Z28
Name that part!
I'm not sure what the name of this part is, I tried to describe it to the guy at the parts store, but I think I knew more about cars than he did(not saying much).
The problem is that it started leaking when the car's cool. I don't know if it's coincidental, but about this same time my transmissoon began acting weird. It seems like it's shifting strangely, especailly when I'm slowing down from 45-50 to about 20, then try to reaccelerate. Does this part have anything to do with that sort of thing, and for that matter, what does the part do?
Old Sep 22, 2005 | 02:01 AM
DJXero's Avatar
Here's the pic. I'm pretty sure the arrow's correct with where the front of the car is, but I might be wrong. The part is about six inches to the front of the U joint in the driveline, behind the transmission and pretty close to the rear of the transmission.
Old Sep 22, 2005 | 07:14 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Engine: 350 sbc goodwrench
Transmission: T-5 in the works
Axle/Gears: 10 bolt 3.42 open
Looks like the speedo cable hold down bracket but
I dont see the speedo cable.
Old Sep 22, 2005 | 12:37 PM
DJXero's Avatar
I thought it was an electronic speedometer. At any rate, the speedo seems to work all right, I just can't figure out what this part does.
Old Sep 22, 2005 | 12:41 PM
mdurbala's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
the picture isnt clear enough, i think we need a picture of you, under the car, pointing at the part
Old Sep 22, 2005 | 12:59 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
That bracket holds down the driven gear housing.
Take it off with a 10mm wrench, if your speedo
is working ok leave it alone.
Thats what it looks like to me.
Old Sep 22, 2005 | 03:57 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
it the VSS.
Old Sep 22, 2005 | 06:10 PM
DJXero's Avatar
If it was faulty, would it cause the goofy tranny problems I'm having?
Old Sep 23, 2005 | 11:15 PM
Doug Gulley's Avatar
Car: A Black One
Engine: 383 Chevy
Transmission: Retro T56... :>)
It's the electronic VSS. It sends the speed signal to the ecm and the speedometer. It has an o-ring that seals the ATF in the tranny. Pull it out and replace the o-ring.
When it leaks, you've lost some of your ATF which could make your tranny shift funny indeed.
Old Sep 23, 2005 | 11:20 PM
darrells3rdgen's Avatar
Car: 86 trans am
Engine: 350 cid from a 69 chevy truck
Transmission: original 700r4
if it's leekining fluid it could cause the trans to run low and start sliping. from the pic you posted the base part is wet. so the "O"ring thats under it could be bad. if thats the problem you could get an "O" ring for under $1.oo.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
