Where do I mount the clutch resevoir?
Old Oct 16, 2005 | 05:11 PM
Overspendin''s Avatar
Car: '88 IROC Convertible
Engine: ZZ4 TPI
Transmission: 5 spd.
Swapping out a '88 305 auto to a ZZ4 T5 setup.
On factory maunuan cars, where is the clutch fluid resevoir mounted?...pics?
Thanks if you can help.
Old Oct 16, 2005 | 05:13 PM
Engine: ZZ4 TPI
Of course that should have said "factory manual "
Old Oct 16, 2005 | 05:14 PM
TA_drag's Avatar
Car: 85 Trans Am
Transmission: t5
mine was mounted to the master cylinder to booster mounting bolts with a special bracket.
Old Oct 16, 2005 | 07:35 PM
purpleZ-28's Avatar
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
i believe your talking about on your stock motor right?
i can make you some pics.
Old Oct 16, 2005 | 07:41 PM
TA_drag's Avatar
Car: 85 Trans Am
Transmission: t5
yeah removed my booster I am just going to secure my resevoir to the firewall somewhere.
Old Oct 16, 2005 | 07:53 PM
purpleZ-28's Avatar
hope this helps.
Old Oct 16, 2005 | 08:08 PM
TA_drag's Avatar
Car: 85 Trans Am
Transmission: t5
yeah thats it.... you dont have a location but if you live anywhere near Tampa Bay area I got one you can have. If not you should be able to get one from the junkyard for a couple bucks.
Old Oct 16, 2005 | 09:12 PM
Engine: ZZ4 TPI
Thanks guys, I didn't get that part off the donor car, guess I'll just order one from the dealer.
Old Oct 22, 2005 | 11:57 PM
purpleZ-28's Avatar
do you have the cap for it? mine is burned, see photo.
jtwoods4
Sep 3, 2015 05:39 PM
tonys91rs
Sep 2, 2015 07:07 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
