what manual trans would work?
Old Oct 23, 2005 | 09:37 PM
tbair's Avatar
Car: 1962 impala
Engine: 305 tpi/1985 z-28
Transmission: 700 R4
I have an 1985 z-28 motor "305" tpi motor and 700r4 trans Im putting into a 1962 impala speedster. A what? 1962 impala speedster top removed winshield lowered 2" no rear seat . you know a speedster.anyway what manual trans will work with the 305 tpi motor. t56 or what was available in 85 ? I know you couldnt get the manual with this motor but shurly someone has done this before.THanks Tim
Old Oct 23, 2005 | 09:43 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Basically anything can be made to work but i have heard mustang t5s mount cockeyed so they might be tricky.
Old Oct 29, 2005 | 07:09 AM
fast82-Z28's Avatar
Car: 1982 camaro Z28
Engine: 350, comp cams magnum 282h cam, edelbrock performer rpm intake, carter 625 cfm carb, msd hei upgrade kit, milodon gear drive, crane cams 1.6 rollers, more 2 come!!
Transmission: th350, 2600 stall, stage 3 shift kit
the fbody t-5 are the ones that mount cockeyed......
Old Oct 29, 2005 | 09:09 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
so the mustang t5s will sit cockeyed when bolted in an f body...
Old Oct 30, 2005 | 09:14 AM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
Forget about the ford tranny it has a diffent imputshaft . You can find a W/C T-5 cheep that will bolt in with the addition of pedals and some Hydros . I belive the bell is what puts you on the angle ,get an impala bell that will adapth the tranny you want . If you plan on making some HP go with a T-56 . Buy a complet parts car if your budget will allow you . They also sell after market trans like the TKO/500 , TKO/600 & aftermarket T-56's . For the price of something like that you maybe able to find a parts car with all the stuff you need for the auto-man swap .
The Impaler sounds bad Good luck.
1992 Trans Am
May 10, 2023 07:19 PM
camaro11j
Sep 19, 2018 08:49 AM
dhonda200
Aug 11, 2015 11:50 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
