Trans Am 700R4 to Corvette 700R4 HELP
Old Nov 2, 2005 | 04:10 PM
85TransAm_FaQ's Avatar
Car: 1985 Trans Am
I am swapping my trans am 305 tpi + trans to a '1986 vette tpi + trans. I switched over the tailshaft from my trans am however, the vette 700r4 case blocks me from installing the stock (trans am) tranny mounting bracket.
Is there any companies making a tranny mounting bracket for this swap, or do I have to custom fabricate something, or reinstall the stock firebird 700r4?
Old Nov 2, 2005 | 05:50 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
why not just swap the goodies? (tq conv, boost valve, etc.)
Old Nov 2, 2005 | 07:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You could swap the tailshaft housing, but the Corvette 700R4s usually have the mounting holes in the wrong spot anyway. Why not just keep your existing 700R4?
Old Nov 2, 2005 | 08:14 PM
Car: 1985 Trans Am
Thanks for the quick replies...
I was trying to adapt the vette 700r4 since I already put it in. Since it doesn't seem like its going to work, I am going to reinstall the original 700r4 with the vette torque converter.
Hopefully the Trans Am 700r4 will bolt onto the vette 350 with no modification?
Old Nov 2, 2005 | 08:26 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yeah, no problems that way.
Old Nov 2, 2005 | 08:56 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
To my knowledge it is not possible to use the vette case. It has the mount area machined out. Drilling and tapping is not possible. Don't throw away the vette stuff. Others(myself included) would by them.
Old Nov 3, 2005 | 08:31 AM
Car: 1985 Trans Am
Im going to reinstall my original trans am 700r4 on saturday.
Will the ECM from my 1985 Trans Am be able to handle a 1986 Corvette 350 or do I have ti upgrade my ECM, or computer.
I am also going to post this tread in the proper tech area.
camaro11j
Sep 19, 2018 08:49 AM
TreDeClaw
Aug 14, 2015 06:58 PM
milk
Aug 10, 2015 06:26 PM
Leggman1
Aug 6, 2015 04:15 AM
