9 bolt, 12 bolt, what's the difference?
Old Nov 7, 2005 | 09:43 PM
drews91maro's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
what is the difference between the 9 bolt? 12 bolt? What does this mean???
Old Nov 7, 2005 | 09:45 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
The 12 bolt has 3 more bolts...
Old Nov 7, 2005 | 10:12 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
While that was a helpful answer, i'll elaborate...
That's the # of bolt holes on the back of the "pumpkin" or differential housing. It's the EASIEST way to tell which it is.
10 bolts are basically the norm for our cars. Weak. 9 bolts are stronger, much more rare, and therefore hard to find parts for.
12 bolts are basically the strongest factory axle GM made, bigger overall, so you can beef it up to be almost invincible
Old Nov 7, 2005 | 10:36 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Strongest ever offered in a car. My truck has a GM 9.5" ring gear 14 bolt. The 12 bolt is only a 8.875" ring gear.
GM offered 3 different 10 bolts. The newest is also the weakest at only 7.5/7.625. They were also offered in 8.2" and the more popular 8.5". Nothing is interchangeable between these diffs.
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
onefreakz
May 14, 2018 12:15 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
