Special holding fixture avail. for dial indicator?
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Im wanting to use a dial indicator to measure the C/L, runout of my bellhousing. For obvious reasons a magnetic base wont work. Is there a special fixture available for holding the dial indicator?
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
You can use the mag fixture. You attach to the flywheel & the pointer goes on the edge of the trans hole. Spin the engine by hand & watch for runout.
Car: 88 Camaro SC
Engine: SFI'd 350
the problem I had with the mag. base was that it moved ever so slightly while I was measuring. My end reading wasnt the same as my start. Even using the alt. pulley to turn the engine over very slowly wasnt enough. The stick/slip of the piston rings was enough to cause it to move.
Car: 88 Camaro SC
Engine: SFI'd 350
Ill probably end up welding a steel rod to an old flexplate to get an immovable reference. Would be nice if they made something for a nominal ammount, though.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I made a custom fixture once to check valve lift on a diesel that had no place for a magnetic base. Instead of using a magnetic base I made an attachment for the dial gauge to screw into a rocker cover bolt hole. A 1/2" rod with a 1/4" bolt welded onto the end of it. I used a jam nut on the 1/4" bolt to hold it tight.
Could a similar device be fabricated to check the runout on the bellhousing?
i ithnk stephen is on the right track, if a mag base doesn't work weld up some bolts or all thread to hold the indicator. i still have several home made indicator fixtures from my karting days.
Run some all thread into one of the flywheel bolt holes & attach the dial indicator to that.
Car: 88 Camaro SC
Engine: SFI'd 350
Im in the middle of swapping over to a tko as well
I could have swore I saw something to do this, oh well. I guess Ill either weld a rod to the flexplate, which is already still attached, or just weld the rod to a bolt. Thanks for the input.
