tv cable problem?
Old Nov 21, 2005 | 06:41 PM
jaysfs's Avatar
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
tv cable problem?
My problems are that when it`s in overdrive and i take off from a dead stop it acts real jerky when i `m not getting on it. it shifts fine when i floor it and also when i manually shift it in gears. Also when i am goin 75 the rpm`s are wrapin round 25-28 grand. i`ve had a b&m shift kit put in the tranny. It was the street&strip one. I`ve tried adjusting it afew times and no luck.So could it be my cable or what i outta idea`s
Old Nov 21, 2005 | 10:30 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Does it do the same thing when you shift it manually?
I would drop the pan and make sure the none of the valves are stuck in the valve body.
TV adjustment is extremely important of these transmissions. Try to readjust it by pressing the lock tab and pushing the cable all the way in (toward the firewall) and then releasing the tab. Now open the throttle to full and it should pull the cable out with it. This will be the max adjustment needed for the cable. If this doesn't work then you have a stuck valve or check ball in the wrong place.
Old Nov 23, 2005 | 09:15 PM
jaysfs's Avatar
Transmission: t56
i have never seen the inside of a transmission though,how could i teel if the valves are sticking?
Old Nov 23, 2005 | 09:32 PM
1981LT1's Avatar
Engine: LT1; LT1
you really need to buy a repair manual that shows pictures and explains what is what, especially if you haven't done it before. Be careful and go slow. If this fails then it might be an internal clutch problem. This would require alot of knowledge and some special tools. I have rebuilt a few of them so let me know what you have done.
9192camaro
16
Feb 3, 2019 12:21 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
timonator
Aug 13, 2015 11:27 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
