Shift kit - $311cdn ??
Car: Custom 1992 Camaro Z28 25th Anniver
Engine: 5.7L V8 350 L98 TPI
I recently got my trasmission fixed and they also installed a shift kit in my 1992 Camaro Z28 with 700R4 Auto Trans.
My Transmission shop charged $311cdn for it? Yet I'm being told they are like $100, IF THAT..
Did they SERIOUSLY rip me off???
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A basic shift kit which is just a valve body reprogram is about $100.
A master rebuild kit which includes a shift kit, all the new frictions, seals etc is around $300
Car: 94 Trans Am
Engine: LT-!
That seems high. Stephen is right at around 100.00 (US)for the kit and since they rebuilt the tranny there shouldnt be any labor for the kit install. 44.56 to road test? I would have thought they wouldnt have charged you for that since you got it rebuilt there. 3500 for a 700 is lot but that is cdn. retail rebuilds here are about 1700.00 US.
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
I think he looked at your car and thought "this guy must be loaded for cash"
I think you got raped for that rebuild. You could have got a brand new trans ready for 450HP for less money.
Car: 87 IROC L98
Originally posted by roughskinjrz
is it a stall coverter
Asking that is as bad as asking if those are "cheater slicks" or if you have a 3/4 race cam.
NHRA427: You'll see they refunded that fee in the totals. Personally I think they charged for too much on everything. $300 to take it out and rip it apart. $1500 to rebuild and another $200 to put it back in. Even at a high shop rate of $70/hour, it doesn't take 3 hours to put the tranny back in.
$5.89 per liter of oil. That better be synthetic for that price.
I'm heading back there on Sunday to have the 2 week check up. What EXACTLY should I ask?
What brand of Shift kit? What TYPE? what else?
Car: 89 RS
Transmission: th350
It is kinda high, my friend paid 1300 for his 700r4 rebuild with a brand new torque converter. 44$ for a test drive when they did labor, sounds like you paid them to take it for a joy ride. I would question them on all of there prices. Did you get a quote anywhere near that?
Car: 87 IROC L98
Ask what brand the shift kind is. What's included in it. If it's just a valve body reprogram, then why so expensive. If a complete rebuild kit, did it include the band that they charged extra for. The receipt says to see reverse for parts and labour included on the rebuild. What parts, how long for the rebuild? A good tranny mechanic should be able to rebuild a tranny in less than a few hours. $1500 is either a lot of extra parts or a few days of labour (just to rebuild the tranny). I wonder just what's included in the rebuild. They didn't have to test the torque converter since you got a remaned one. It was already disassembled. Replacing hard parts like sprags, and drums could add to the cost but a typical rebuild kit will include everything except hard parts and should come with the band.
What gets me is $300 to pull and disassemble the tranny so the "rebuild" won't include disassembly. Another $200 to put it back in the car then another $65 to fix any mistakes they made installing it.
As I already mentioned, the $44 test drive was refunded when the work was done.
I haven't had to buy normal ATF for a while but $5.89CAD/liter seems a little high but I could be wrong.
It's hard to fight labour costs if you don't know exactly what they've done. When I'm working on a vehicle and it takes longer to fix something than normal, the final bill could have a long repair time. I justify it by explaining on the work order why it took so long. Rusted bolts that needed to be cut, drilled out and retapped etc, removal of other items to access the part that needs repair etc. The boss can then decide if all the time should be charged to the customer or if he'll give the customer a deal. If I make good time on one item of the job, excess time can be moved to it from a different item to balance things out. Most of the time I have multiple jobs to do on a single vehicle so that can work.
I guess the biggest things to question would be the $300 for the shift kit and the $1500 to just rebuild a disassembled tranny.
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
I got some tranny work done to my GTA this summer and this is what I paid to get the work done:
Sonnax .500" Boost Valve - $28.95 (part #: 77917-500)
TransGo Shift Kit - $94.50 (part #: SK700)
Corvette Servo - $65
Shop Supplies $5
Labor - $192
GST - $26.99
PST - $26.99
Total - $439.43 Cdn
I supplied my own tranny fluid and I had them put in a new filter and shifter seal. I probably could have gotten the parts cheaper through a local speed shop but I didn't know the part #'s/brands to buy for the Boost Valve and Servo.
Sorry to say this but you got gouged big time on the shift kit and boost valve. Did you get the shop to install a Corvette Servo? The Corvette Servo firms up the 1-2 shift.
Shop Supplies $5
Labor - $192
GST - $26.99
PST - $26.99
Total - $439.43 Cdn
OK. Talked to tranny shop.
They claim they installed a "Sonnax TH700 R4 Shift Kit"
The only thing it included was the valves and tougher springs. No drilling.. No bands, no other stuff..
Car: 1988 Pontiac Firebird Formula 350
Engine: 5.7L
Transmission: Automatic 4 speeds
Axle/Gears: 2.77
You got ripped BIG time! I had my original 700R4 rebuild a couple of yeares ago and it cost me 1200$ CANADIAN... They didn't put in a shift kit but the whole trans was redone anyway. Even with a shift kit it wouldn't have cost me more than 1500$ CND.
Car: 87 IROC L98
I'd contact your local Better Business Bureau and have them check out the tranny shop. Sounds like they really ripped you off.
lesson learned.. Can't go to the BBB as the problem isn't fixable. They have 4 complaints in the last 36 months. ONLY was resolved. 2 unresolved, 1 unresponded to..
"Customer Experience
Based on BBB files, this company has an unsatisfactory record with the Bureau due to failure to respond to one or more complaints and or two or more otherwise unresolved complaints.
When considering complaint information, please take into account the company's size and volume of transactions, and understand that the nature of complaints and a firm's responses to them are often more important than the number of complaints.
The Bureau processed a total of 4 complaints about this company in the last 36 months, our standard reporting period. Of the total of 4 complaints closed in 36 months, 0 was closed in the last year.
These complaints concerned:
1 Product Issues
1 Billing or Collection Issues
2 Service or Repair Issues
They were closed as:
1 Resolved
2 Unresolved
1 No Response
1 Product Issues
1 Resolved
2 Unresolved
1 No Response
QUESTION: is this true or are they lie'ing RIGHT TO MY FACE?
Ever since I got the car back, the shifter indicator at times will going 1/8th PAST the OD reading. Then I need to tap the shifter to put it completely into OD.
They said this is your Shifter cable and that it is UNFIXABLE. You must replace the cable as it is UNADUSTABLE. It's not too expensive for the cable but at least 3 hours for labor and is NOT cheap.
Correct me if I am wrong however I have ALWAYS been told you could adjust the ATV (is this the shifter cable?) so WHY are they telling me it's UNAJUSTABLE and I have to buy a new one!!
My guess at least a $500 if not more.. job if they charge like $85/hour cdn. plus the cable and tax..
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
