VSS problems
Old Dec 20, 2005 | 06:28 PM
harpo_87's Avatar
Car: 91' Camaro RS
Engine: LO3 305
Transmission: Built 700R-4
VSS problems
im replacing the VSS on my 91 camaro with 700R4 and i need to know which way the gear faces that attaches to the senser, if the front of the car is ^ then is the gear < or > if you understand what im sayin can you help me? and if not i might be able to clarify a bit more
thanks alot!!!
Old Dec 20, 2005 | 06:34 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Old Dec 20, 2005 | 06:41 PM
harpo_87's Avatar
Car: 91' Camaro RS
Engine: LO3 305
im sorry that dosent help much
Old Dec 21, 2005 | 02:21 PM
goose21's Avatar
Car: 85 Monte Carlo, 93 C1500, 98 Neon
Engine: 355, 4.3L, 2.0 DOHC
Transmission: T5, 4L60E, T350
Axle/Gears: 2.73, 3.42, 3.94
I get what you're sayin.
Front of car ^ VSS gear >
When you're looking at the assembly, the whole thing will be streamlined; kinda like a bullet.
If the gear is oriented to look more like an open bowl, it's wrong.
Old Dec 21, 2005 | 04:14 PM
harpo_87's Avatar
Car: 91' Camaro RS
Engine: LO3 305
thanks, ok then i did put it in right, so now i just have to figure out why my speedo doesnt work! grrrr but thanks again!!
pjsparts
Oct 29, 2025 06:39 PM
GTAman
Jul 3, 2024 07:29 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
