T-10>t-5?
1 Post
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
i beleive there were 2 different kinds of t-10s someone will chime in but, yes the bw super t10 was 1 that was available in 1982 at least (neighbor has 1 in his 82 maro). It handles his 400-450hp quite easily it seems anyways so they are most definetly tougher than a t5.
As for why gm switched to a t5 well maybe different ratios maybe people just wanted a 5 speed. Maybe the bw was more expensive as i'm not a gm market research guy i couldn't realy tell you.
Best gm question of all being why did they stop making f-bodys?
i honestly don't know. All i know is they didn't sell half as many as they should have in there later years.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
in 82-83 you could get the crappy saginaw ( reverse in bottom left), or the good T10 (reverse is top left). The T10 is very strong from what i've heard, and is a good solid close ratio trans.
The T5 is an overdrive trans, and overdrive was becoming the way of the future, so cars were swapped over to that.
1 Post
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
are these bw t10s hard to find. and how much do they usually go for? would it be much different than swapping from auto to a t5? thanks a lot.
Car: 1982 Trans-Am
yes, i'm pretty sure they're hard to find.
if you already have the standard, it'd be easier then swapping from one standard to another, then auto->stick....
you could probably re-use the hydraulic clutch setup, but you'd need a different driveshaft I think, and torque arm.
Why downgrade to a non-od trans though?
1 Post
well i wanted to do a manual conversion anyways, and i wanted to rest assured about being able to handle my motor. and yea, t56 is a little higher priced than i was looking for.
and what about bw t10s from other years? like late 70s, are those useable in our cars, or too much work? thanks.
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The T10s designed for 3rdgens are difficult to find... took me 2 years to find a good setup from an '82 Trans Am!!
The older T10s from the 60s and 70s will work, BUT you must have a swap kit for it, which means a torque arm mounted somewhere other than the side of the trans, because there is nowhere to bolt it onto the trans on any but the 3rdgen-specific T10s.
Spohn (see sponsors at the top of the page) makes a crossmember/torque arm kit to install an old-style 4-speed in a 3rdgen chassis.
1 Post
what else would you need besides the regular t5 swap stuff if you went from a 700r4 to a t10? is it the same stuff?
is this the third gen one?
http://cgi.ebay.com/ebaymotors/camar...QQcmdZViewItem
that swap stuff is way too expensive for the older t10s.
1 Post
You'll need a longer driveshaft as well, since the T10 is shorter.
I can't tell if thats a 3rdgen T10 or not, I can't see the torque are mounting holes, which would be right under the shifter.
Re: T-10>t-5?
Received 1,672 Likes
Re: T-10>t-5?
Looks like the EXTREMELY wide ratio version (2.9x 1st gear if memory serves), by the 3 bands cut in the clutch splines; non-"Super" (10-spline 1-1/16" clutch); doesn't look like a 3rd gen one at all of course. Looks like the BH has the large dia hole for the clutch gear bearing retainer, which means it's out of a truck.
Probably out of a mid-60s truck.
Re: T-10>t-5?
OP: Give D and L call, they really know their stuff and stand behind their work. I bought a rebuilt muncie from them years ago, still runs great.
http://www.dandltransmission.com/
luvofjah
09-26-2015 08:28 PM
