150mph with 4.11's
Old Dec 29, 2005 | 11:19 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
150mph with 4.11's
Just messing around with my engine calculator and found out that with the overdrive the 700r4 offers, 150 mph is attainable with 4.11's and a redline of 5700 rpm(where mine is set). I figured I'm going to swap my rear gears anyways might as well go pretty steep.
The calculator shows a final drive of 2.87 in OD, and with 26" tires 150mph is redline top speed. The question is will it always rev super high before shifts or will regular shifting(under 3k) happen. I will be using the stock convertor and a trans-go shift kit that allows full manual shifting. Sounds like tons of tire-smoking fun with decent fuel economy(although it's not really a concern).
Old Dec 30, 2005 | 03:34 PM
brutalform's Avatar
What intake do you have?
Old Dec 30, 2005 | 06:50 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
4.11`s with my 85Z, 7004 equipped ran around 2800 at 65MPH with a 9 inch 3,000 stall in OD....as for 150MPH with them...I`d be impressed I run 11.20`s and went thru the traps at 7,800 w/4.11`s in third w/ 26 inch DR`s. I have went to 3.73 and I launch harder and faster with 26`s.
changing gears is a I`d go 3.73 with 26`ers though....28`s... I`d do the 4.11`s in a heartbeat!
Old Dec 31, 2005 | 12:17 AM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
150 is possible, but only in theory. Just because the gearing is right for that speed doesn't mean everything else is. Getting to 150mph would take a lot longer with 4.1 than 2.73. Besides, getting to that speed takes a lot of horsepower. Not saying it isn't possible stock though.
Old Dec 31, 2005 | 12:04 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
nope, getting to 150 is faster with the 4.10's than with 2.73.
Overall acceleration is quicker with the lower gears (lower gears are the numerically higher numbers).
Old Jan 1, 2006 | 10:14 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
yes, that is with zero slip speed.....
Old Jan 2, 2006 | 01:46 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
i don't know how that would work because, correct me if i'm wrong, OD won't be able to engage if you're at WOT.
Old Jan 2, 2006 | 02:09 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Sure if you have the engine to pull it to 5700 RPM it could do it. Of course like mentioned you need to be able to keep in it OD.
Old Jan 2, 2006 | 05:21 PM
Zepher's Avatar
when my car was auto, it would upshift to OD at WOT. Trans was stock too.
http://www.transamws6.com/video/130mph.wmv
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
darwinprice
17
Oct 11, 2015 11:51 PM
JSDaddy189
Sep 26, 2015 03:50 PM
Dialed_In
Aug 20, 2015 01:45 PM
RMK
Nov 19, 2000 08:17 PM
