Doing the t5 swap. What parts should I look for new?
Old Jan 11, 2006 | 08:27 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
I bought a complete swap kit, but im sure the parts are nothing special. i was told to get a new clutch disc, pressure plate, and hydraulic set up. do you agree with this?
Old Jan 12, 2006 | 09:06 PM
ZZ4 86 Z28's Avatar
im not asking if its possible or anything like all the others who do not search.
Old Jan 12, 2006 | 11:06 PM
meangene83's Avatar
Car: 91 formula
Engine: 355
i would definitely get a new disc, pressure plate, throwout bearing, pilot bushing and have the flywheel surfaced. I would probably try to re-use the hydraulics. I reused them on my swap and they've worked fine for a few months now, just depends on if you want to gamble since the clutch master is no fun to install.
Old Jan 13, 2006 | 09:49 AM
ZZ4 86 Z28's Avatar
is there another name for the throwout bearing? like a release bearing?
Old Jan 13, 2006 | 12:35 PM
meangene83's Avatar
Car: 91 formula
Engine: 355
yep, it's the same thing
Old Jan 13, 2006 | 01:00 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
new clutch/pressure plate... re-use the hydraulics if you can like was said up above.
im going through this swap also, dont want to use a stock clutch lol
Old Jan 13, 2006 | 05:34 PM
ZZ4 86 Z28's Avatar
apparently the clutch is new i just found out. but its not really a nice one/big deal or anything. ill check it out when i get it.
Old Jan 13, 2006 | 06:22 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
oh you didnt get it yet? which year is the transmission from.
Old Jan 14, 2006 | 02:13 PM
ZZ4 86 Z28's Avatar
i bought an 88 v8 tranny. and from somebody else i got the rest of the swap parts. the entire swap, except the torque arm mount. the guy who sold me the swap told me the clutch in the package was new and he didnt remember what brand and it was for performance.
Old Jan 14, 2006 | 03:52 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
thats good, its from an 88, so its a world class
Old Jan 14, 2006 | 11:59 PM
ZZ4 86 Z28's Avatar
i was aware of that. with the new motor i had to be sure to get one of those if i wanted it to last more than 5 minutes.
Old Jan 15, 2006 | 01:24 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
is there a guide you use to make sure you do anythin right? or dont forget anything? im trying to find one on this site like a sticky but i cant
Old Jan 15, 2006 | 11:16 PM
ZZ4 86 Z28's Avatar
go to thirdgen.org but not the forums. then on the left click technical articles. scroll down that page until you hit a section of links in transmission. there will be one called auto to manual swap in an fbody. they fail to mention the torque arm mount however.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
sreZ28
Aug 14, 2015 07:48 PM
1nastygta
Aug 8, 2015 07:38 PM
