Help putting together -6 ss braided lines & connectors
Old Jan 23, 2006 | 08:26 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I bought Aeroquip -6 fittings and -06 SS braided lines to replace the rubber lines from my tranny to the cooler.
I can not get the SS line to go inside the fittings!!!!!
The fitting measures 0.50" ID,,, the OD of the SS line is about 0.57 to 0.58"...And I have tape on the OD of the SS line so I have a clean cut from the factory.
This is beginning to pi$$ me off. What is the trick?
Old Jan 23, 2006 | 08:56 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Lubricate
Old Jan 23, 2006 | 09:33 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
An hour ago, I put axle grease inside the fitting and on the SS braided wire, and tried to use a screwdriver to force the SS line inside the fitting. It did not work!!!!!!!!!!!!!
Old Jan 23, 2006 | 10:00 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
-6 lines are the devil. personally i wrap electrical tape around them very tightly and leave the end about 4 inches off. then pull the loose end through the fitting and then shove and twise back and forth the line into the fitting and pull out the excess electrical tape. cussing may be needed/warranted as assembly commences.
Old Jan 24, 2006 | 07:20 AM
Ricktpi's Avatar
I wrap the tape like stated above & then lightly bevel the cut wire end on a grinding wheel.
Old Jan 24, 2006 | 10:59 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Put a hose clamp on the end without about 1/6" of the hose sticking out and tighten it just enough to compress the braid slightly so you can start it in the sleeve.
Old Jan 24, 2006 | 11:48 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The inside of the sleeve is threaded, IIRC left hand, need to turn it onto the hose.
RBob.
Old Jan 24, 2006 | 12:12 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Thany you for the help. I'll let you know how it goes.
Old Jan 24, 2006 | 05:44 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I don't recall the inside of the Aeroquip sleeves being threaded, only barbed. Twisting either way once the braid is all tucked in helps though.
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
