Changing T-5 question
Old Jan 28, 2006 | 12:09 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Ok my car cureently has a WC T-5 and it is shot. My simple question is that if I were to come across a cheap non-WC tranny would it bolt right in, and will it affect how fast my car is? Thanks guys.
Old Jan 28, 2006 | 11:38 PM
qytum's Avatar
Car: 92 Formula
Engine: 5.0L TBI
Axle/Gears: 3.73 posi
Yes, you can interchange them. As far as affecting your acceleration, it will a bit in 1st. I believe the WC T5's had a better 1st gear ratio. But I don't think you would notice too much unless its a track car.
Just remember to swap your speedo gear(s).
Old Jan 29, 2006 | 10:54 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
No and Yes, when it comes to T-5's there are 18 spline shafts and 28 spline shafts (might be off on the numbers, been awhile) The V-6 used the lower number shaft while, of course, the V-8 the larger. So, a V-8 T-5, non-world class will fit right in. But remember, if your car runs a VSS speedometer (electronic) and you pick up a manual speedo cable transmission, like I think all non W/C T-5's were, you'll have problems there too.
Frozer!!!
Jan 19, 2024 04:55 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
