PICs attached T5 swap question flywheel
Old Feb 5, 2006 | 11:45 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Engine: 350 sbc goodwrench
Transmission: T-5 in the works
Axle/Gears: 10 bolt 3.42 open
I guess this would be a tech question.
Should I use this flywheel or not?
I have this flywheel and clutch disk pics
the flywheel surface area doesnt completely
cover the disk since the diameter is larger..
Old Feb 5, 2006 | 11:49 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Pic of flywheel inside diameter
This is the flywheel inside diameter surface area
which is larger then the clutch disk area..
Old Feb 5, 2006 | 12:15 PM
Doesn't look to me like the right flywheel.
Looks like a 14" flywheel.
If it is, it won't fit in your bell housing anyway, so you won't really have to worry about the clutch friction dimensions.
Old Feb 5, 2006 | 12:22 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Its 12 3/4 153 tooth
This is the the flywheel I got off ebay from ams racing..
Old Feb 5, 2006 | 12:43 PM
If it's really 12.8" outer diameter, it should be OK, the little bit of clutch friction on the inside won't matter.
Old Feb 5, 2006 | 12:47 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Thats what the seller said it shouldnt matter
but I dont want to bolt everything up and it slips
I really would like to see another flywheel first before
I decide what to do.
yeah this one isnt 14 inch
Old Feb 5, 2006 | 01:06 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
How does it fit the clutch plate? If it's a perfect fit I would be looking for another flywheel. Once you start getting some wear on the disc your going to have uneven wear on it that might cause some chatter engaging the clutch in first or reverse under normal conditions (street driving). Opinions anyone?
Old Feb 5, 2006 | 01:09 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Clutch disk fits perfect with the pressure plate
pressure plate bolts up to the flywheel no problems there.
The surface area of the flywheel to clutch disk has
me worried seems to me that if anything the flywheel
suface should overlap the clutch disk not the other way
around.
Old Feb 5, 2006 | 01:31 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
I think the disc should fit exactly with no overlap. It looks like in your pic. you have a 3/4 in difference. that's 3/8 in of disc that's doing nothing! as your disc wears, it's going to build a lip on the flywheel side. One would think that might cause cracks and possibly chip off the disc (not good). Being the seller said "IT SHOULDN'T MAKE A DIFFERENCE" means their not sure but it will work. Yes it will, but how good and how long? Like you, I would do some more research before final installation just to be sure.
This topic isn't over and I'm sure you'll get more imput on this.
let's wait and see what other's have to say!
Old Feb 5, 2006 | 01:38 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
sounds good to me
I think ill go to auto part store to see
if they have some flywheels i could check out
Old Feb 8, 2006 | 10:11 PM
87camaroz28310's Avatar
Car: 87 plane jane with gfx
Engine: 350 worked vortec head .515 .515 cam and 1.6 rockers and shorties for now til i can afford the supercomps
Transmission: super t-10 or t-5
Axle/Gears: auburn with 3.42 stock axles
i bought the same flywheel of ebay, i think it's for a two piece rms engine right? if that the one you got i didn't use cuz i sold the car but the guy i sold it to used it and it seems to work fine. but he's also use an aftermarket zoom that i sold him with the car. and if thats a stock clutch and i read you info right your 350 will probably kill it pretty quick
Old Feb 8, 2006 | 10:35 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
yeah I got that off ebay also and sent it back.
Its from AMS racing 2 piece they have another one that they say fits better but its 50 dollars more and weighs more also,
so I just might try the Gm lightweight flywheel.
I guess its a stock clutch disk from luk and valeo
I have 2 of them so if they dont hold up well Ill get a better one.
Looking forward to do the T5 swap just cant get all the
parts together yet.
92projectcamaro
Sep 29, 2015 07:07 PM
ndndndnd
Sep 28, 2015 08:00 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Ian Irvine
Sep 4, 2015 08:08 AM
