Wont shift from 3 to 4 under WOT?
Old Feb 5, 2006 | 08:14 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Wont shift from 2 to 3 under WOT?
Hey guys, my 700r4 will not shift into 4 when i have the throttle wide open. My car is an 88 with 350 and 3.42 gears. When I go WOT it will run up to 70 and the engine will just keep climbing in rpms, the highest I got was to 6000. When I let off it shifts fine. By the way it is a stock converter. Is something sticking or is it supposed to do that?
Old Feb 5, 2006 | 08:38 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
It is supposed to do that. Vettes and police cars have a different valve in the valve body that allows for the 3-4 upshift at wide open throttle.
Old Feb 5, 2006 | 09:39 PM
1BADROC's Avatar
Car: 1989 IROC-Z
Axle/Gears: 9bolt 3.27
you mean 2nd to 3rd right 700r4's 4th is overdrive. your unlucky some wont shift like your describing at wideopen throttle some will mine would everytime. i dont know what to tell you other than maybe adjust your cable.
Old Feb 6, 2006 | 11:34 AM
3rdgenmaro's Avatar
Car: 88 IROC
On second thought, IBADROC must be right, it must be the 2 3 shift. Is this still caused by the same valve? I also forgot to mention that I have a bm shift kit in it as well. Also when I am going down the road about 40 or 50 and I go WOT the motor just revs and I dont feel the car want to go forward. It just feels like it is in neutral. Could this be caused by the same valve that you guys were talking about?
Old Feb 6, 2006 | 06:57 PM
87camaroz28310's Avatar
Car: 87 plane jane with gfx
Engine: 350 worked vortec head .515 .515 cam and 1.6 rockers and shorties for now til i can afford the supercomps
Transmission: super t-10 or t-5
Axle/Gears: auburn with 3.42 stock axles
you or whoever installed the shift kit probably put the wrong springs in the wrong spots or something
Old Feb 6, 2006 | 08:05 PM
3rdgenmaro's Avatar
Car: 88 IROC
im 99% certain that it is in right. I done the hardest shift and it replaced all the accumulator springs with spacers. It also replaces one spring inside the valve body with a spacer. So Im sure i didnt do anything like that. But I could be wrong.
Old Feb 6, 2006 | 08:16 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
The mistake most easily made with the B&M kit is putting the wrong checkball placement.
Old Feb 6, 2006 | 09:57 PM
3rdgenmaro's Avatar
Car: 88 IROC
i thought about that too. that could be a possibility. when I dont drive it aggressively it drives and shifts fine through all gears. I just dont know what it all could be. I have never driven a stock 700r4 before. Im not really sure what to expect out of one. If it were a check ball would it shift correct at all?
Old Feb 9, 2006 | 09:48 PM
3rdgenmaro's Avatar
Car: 88 IROC
how do stock 700r4s perform? I mean how did these cars shift and work when they are new?
Old Feb 9, 2006 | 11:41 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
pillow soft, like a cadilliac.
Old Feb 10, 2006 | 12:01 AM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
ha, pillow soft, that's actually a good description.
Old Feb 14, 2006 | 12:22 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
my stock 700R4 would upshift to 4th in WOT. most of my friends cars wouldn't.
http://www.transamws6.com/video/130mph.wmv
Old Feb 14, 2006 | 10:15 AM
3rdgenmaro's Avatar
Car: 88 IROC
i guess it is supposed to do that then. I can hold mine down and the fastest it will run is around 80 as well. Thanks for the video.
Pac J
May 17, 2020 10:44 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Damon
Sep 26, 2015 04:29 PM
