axles
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
axles
I have an 89 iroc with 2.73 limited slip, If I go to the junkyard, what cars can I search to find one that will fit, S10, Caprice, or what...
I want a 3.23 or 3.43 with drums
some help would be nice...thanks
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Not exactly sure on the question. Are you looking for axles, a complete diff or just the gear set with carrier?
The only factory axles that will fit into a third gen housing are out of another third gen. 82 - 89 have 26 spline. 90-92 are 28 spline.
The only diff housing that will fit into a third gen is from another third gen or a fourth gen. Because of the torque arm mount, no other diff will fit without changing the rear suspension.
As for gears and carrier, GM produced a lot of 7.5/7.625 diffs. You can pull the gears and carrier out of an S10 and put them into your 10 bolt. Many of the RWD drive cars also had that tiny diff but you need to know how to identify them. Some also came with the 8.5" 10 bolt.
Car: 89 iroc
I was looking for complete drum to drum, but you answered my question.......I'll need to find one out of a third gen,,,,
I think finding a limited slip in a s10 is going to be pretty hard to find...
but hey thanks anyway
Car: 87 IROC L98
Sometimes it's just hard understanding the terminology
Common: Carrier/Posi/LS
Proper: Differential
Common: Axles
Proper: Half shafts
Common: Differential
Proper: Axle or Diff housing
Common: Axles
Proper: Half shafts
Car: 89 iroc
I know all about that, I work for Eaton Corp. on semi trucks, axles brakes, clutches and transmissions and deal with carriers, (pigs), chunks and whatever else someone might call them....
no discounts on carriers though I've tried
[ON] 9 Bolt Axles Partout
6speedIROC
16
Mar 15, 2023 08:33 PM
rudolphschenker
Sep 4, 2015 02:41 AM
