Can I determine what differential a car had by it's vin?
Old Feb 11, 2006 | 12:24 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Can I determine what differential a car had by it's vin? I know it has a 5spd and a posi rear. Other than that I have no idea. There are also no RPO codes on the car anymore.
Old Feb 11, 2006 | 01:10 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
No info from the Vin number. Pull the cover and check the ring gear the ratio is stamped on the OD.
Old Feb 11, 2006 | 01:15 PM
brutalform's Avatar
You can tell by the build sticker. My F/B has it located on the inside lid of the storage compartment in the hatch. The only problem is, you will need a code book to break down the codes on it. IIRC the rear code begins with "G". Just like the engine codes begin with "L". You probably have a 3.42.
Old Feb 11, 2006 | 01:51 PM
2kflhr's Avatar
Car: '68 396 SS/RS, '02 SS
Other than the option code sticker, the info is alson on the left axle tube.
Old Feb 11, 2006 | 01:59 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
If your car is a 90 and up, a GM dealer can pull the RPO's by vin # and see what it came with. If you want, you can PM your vin and I can run it at work on monday for you.
Old Feb 11, 2006 | 02:18 PM
Car: 1994 Trans Am
It's not from my car. But from a local guy that I might buy the posi-diff from. I haven't seen the car yet. I just don't want to waste both mine and his time.
Brutalform, do 1989 cars have the rpo's in both places, the center console and in the rear storage compartment? I thought the older cars ??-89 had them in the console, and the 90-92 had them in the rear compartment. Was '89 the x-over year for that, not 1990?
Old Feb 11, 2006 | 04:15 PM
Lo-tec's Avatar
RPO's will be in the car in only one spot. IIRC, my friends 89 IROC had it in the center console. The 92 I removed of it's interior was in the rear compartment storage lid.
Old Feb 11, 2006 | 04:51 PM
brutalform's Avatar
Not really sure, I do believe Lo-Tec is right. Depends on the car, and year.
Also if you want to check the ratio, and the rear is out of the car, spin the axle hub one complete revolution. Then count how many times the pinion yoke spins. If the yoke spins almost 3 1/2, its a 3.42. 3 1/4 turns, its a 3.23. This works if you dont want to pull the cover. (a little pass 4 turns, 4.11, but I doubt it would be that, unless they were changed)
Old Feb 11, 2006 | 05:04 PM
jetblast's Avatar
Car: 91 z28 convertible
Transmission: 5 speed
This is the way I found out when I was looking for a complete rear end for my camaro at the junkyards. On the right side of the rear end there is a number stamped. Then with the hayes manual, you can crossreference it.
Old Feb 11, 2006 | 05:09 PM
brutalform's Avatar
One time I had the number on the pass. side axle tube referenced, and it said my car should have had a 3.73 in it. My 92 Formula actually had 3.42 stock. Either someone at the factory, either stamped it wrong, or my eyesight is getting really bad. I even used chalk to expose it better. BTW, the car had under 10,000 miles on it at the time. No dirt.
Old Feb 11, 2006 | 06:07 PM
Lo-tec's Avatar
Last cars to come with 3.73's were L69 HO's. No FI cars came with that ratio . What were you using as a reference to get the gear ratio?
Old Feb 11, 2006 | 10:02 PM
Car: 1994 Trans Am
Here's the vin: 1G2FS2181KL255346 It's a formula and has a 350. And again, it does have posi. Now as soon as I can, I will see how many times it takes the yolk to spin vs. the wheels.
Anyway I can tell if the rear is good or bad, with out running the car? I'm sure the motor/tranny is gone.
Old Feb 12, 2006 | 11:08 AM
brutalform's Avatar
I believe it was a Haynes, or a Chilton manual. 3.42 were the steepest gears you can get stock, in a third gen.
Old Feb 12, 2006 | 01:29 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
A 1990-92 Formula 350 will probably have the 3.23 ratio 10-bolt rear end. A 87-89 Formula 350 will probably have a 3.27 ratio 9-bolt rear end.
Old Feb 13, 2006 | 02:50 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Nada on the VIN. GM does not have RPO records for this vehicle.
Attached Thumbnails Can I determine what differential a car had by it's vin?-vin.jpg
Old Feb 13, 2006 | 06:25 PM
Car: 1994 Trans Am
Thanks Rick.
I looked into something about what can be causeing my rear to make such horrible noises. <------ Mexican food. J/k!!!
I have never put in GM posi-fluid, but just the off-the-shelf stuff from Vato-zone. Not that I was cheap or anything, I just didn't know. People say they get a grinding when they put the other crap in, but as soon as they throw the GM stuff in, the noise goes away. I will be trying that this weekend.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Sep 2, 2020 07:13 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
