Switch from B&M to Transgo.What do I need?
Old Feb 16, 2006 | 01:09 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Is there anything else I need to get to switch from A B&M to A Transgo?What problems might I run into?
Old Feb 16, 2006 | 07:09 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Just time, money and an attention to detail. The transgo kit is much more time consuming than the b&m kit. Mods to the worm track in the case, 4th accumulator block off, valve body mods and servo mods add to it. You will want to pick up a new seperator plate as well. The 87 and up use a 2 letter system to id them. Either buy a universal trans go plate and mod it accordingly, or drop the pan and look between the 1/2 accumulator and the aux valve body. The 2 digit code is there. Order an exact replacement from gm. Either one will work. I prefer the gm.
Old Feb 16, 2006 | 12:54 PM
Demon355's Avatar
So the TransGo kit comes with all of that? I didn't know that, cool!
Old Feb 16, 2006 | 02:57 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
Also, the transgo kit does not come with a pan gasket and filter. Pick up one of those as well.
Veaceonee
Sep 29, 2016 08:15 PM
RacerM
Sep 28, 2015 04:25 PM
tglennon11
Sep 23, 2015 05:30 PM
327IROC85
Sep 23, 2015 12:11 AM
Randomtask2
Sep 10, 2015 08:37 AM
