slipping 700r-4
Old Feb 26, 2006 | 02:48 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
slipping 700r-4
My 700r-4 transmission has a delay going into reverse like 5 sec when cold and slipping also forward is ok.when it gets warm it work alittle better.
Old Feb 26, 2006 | 05:32 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
You are lucky. It is giving you warning. Most don't. Sounds like rebuild time.
Old Feb 26, 2006 | 08:57 PM
antoine's Avatar
I rebuilt it before but what is needed this time.are reverse and forward the same clutches.
Old Feb 26, 2006 | 11:00 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
forward and reverse are not the same clutches. when you "rebuilt" it, did you check clutch pack clearances or just throw it back together with replacement clutches?
Old Feb 27, 2006 | 09:03 AM
antoine's Avatar
i had a friend that works at a transmission shop he setup my 3-4 clutch pack and i installed it with the trans go shift kit.
Old Feb 27, 2006 | 11:20 AM
87zjeff's Avatar
this isn't the 3/4 clutch pack in question. it is the reverse input clutch in question.
Old Feb 27, 2006 | 01:02 PM
antoine's Avatar
reverse input clutch,but reverse works ok when trans is warm.
Old Feb 28, 2006 | 08:56 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
Your best bet would be with the trans builder. He knows what is in it, what he did(or didn't do) and where to look. Gonna be tough to find an exact answere here. If it is slipping at all, and fluid level is good,you are gonna have heartburn regardless.
db057
Jan 10, 2020 08:55 PM
jrdturbo
Mar 31, 2016 02:58 PM
camaronils
Sep 20, 2015 02:57 PM
Fox118
Sep 12, 2015 09:29 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
