what tranny mount to get? how to fix?
Old Mar 1, 2006 | 02:53 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
my car has a broken tranny mount. how do i fix this
more importantly, what tranny mount should i get? GM wants somewhere around 100 for a mount. i see them on Summit for 50 bucks. what would you recommend for a street driven car with a shift kit, 3.73's, and reliability in mind?
where am i supposed to place the jack under the transmission?
Old Mar 1, 2006 | 03:03 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Try NAPA online.
http://www.napaonline.com/MasterPage...rtNum=17982949
Put a piece of 2x6 under the pan & jack from there.
Old Mar 1, 2006 | 04:31 PM
rwdtech's Avatar
how about this mount? Energy Suspension Transmission Mount is polyurathane bad for street use?
Old Mar 1, 2006 | 05:26 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
i use it everyday
Old Mar 1, 2006 | 06:39 PM
MdFormula350's Avatar
get the prothane one from spohn.net
http://www.spohn.net/product.cfm?productid=1349
i like it alot. been taking the abuse for 2+ years now.
Old Mar 1, 2006 | 06:46 PM
rwdtech's Avatar
i heard people say its bad to use polyurathane tranny mounts when you still have the stock motor mounts, is this true?
Old Mar 1, 2006 | 08:34 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Polyurathane shouldn't matter with stock motor mounts. Polyurathane is more durable than you're off the shelf OEM rubber types. I've been using an OEM AutoZone replacement for a long time with my 2500 RPM tq converter, but I also use a Spohn tq arm that doesn't put pressure on the mount. I'd spend the cash for the polyurathane one.
IMO only time you run into trouble is when you're using solid transmission mounts with rubber or polyurathane motor mounts. The motor tqs over and the transmission does not give at all and usually results in cracked case. Or you're using both solid mounts on the motor and transmission. You have to be very careful about that. Usually the fix for that is to use solid mounts for the motor and polyurathane for the transmission, so it has some give.
Old Mar 2, 2006 | 12:09 PM
WckdDudeMan's Avatar
just fyi, the energy suspension tranny mount is only 20$
WIzmo
Aug 30, 2015 02:30 PM
Thornburg
Aug 25, 2015 01:46 AM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
