Rear End Grease Question
Old Mar 12, 2006 | 10:46 PM
LedZep's Avatar
Car: 1990 Formula Firebird
Engine: 305TBI w/ Functional Sport Hood CAI
Axle/Gears: SLP Posi and 3.23 Gears
Hey guys its been awhile since I have posted and I have a question. I am about to pull my 2.73 open out of my 90 Formula and stick in a SLP Posi (out of an 02 SS Camaro) and 3.23 gears. My question is what grease do I use regular, synthetic or blended and what weight range?
Old Mar 12, 2006 | 11:48 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I used 75W90 axle oil. Perhaps posi additive, if it's a clutch style posi. Synthetic if you have the cash to shell out for it. Redline shock proof is supposed to be very good.
Old Mar 13, 2006 | 03:27 AM
ede's Avatar
ede
i use M1 in everything i have
Old Mar 13, 2006 | 08:42 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Me too--GM additive with the rear
JamesC
Old Mar 13, 2006 | 09:15 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
i run royal purple in everything, 75w90 Max Gear in my trans and rear. Goes into gear a lot better so it can't be bad stuff.
Old Mar 13, 2006 | 11:49 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Unless your refering to another trans, the 75W-90 might be a tad thicker then the factory spec'd ATF
Old Mar 13, 2006 | 11:56 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Just a touch!
Old Mar 14, 2006 | 08:37 AM
Dialed_In's Avatar
It's a T5
Old Mar 14, 2006 | 08:54 AM
Car: 88 Camaro SC
Engine: SFI'd 350
I might be wrong, but ATF (or some derivative thereof) is spec'd for just about all of the BW/Tremec units (T-5, T-56, etc.)
Old Mar 14, 2006 | 09:52 AM
Sonix's Avatar
Car: 1982 Trans-Am
yea, apparently afte '85 or something the T5 (manual trans) called for auto trans fluid.... Go figure....
A recent thread was about that, sofa posted that info I think...
Old Mar 14, 2006 | 09:53 AM
Dialed_In's Avatar
Mine's out of an '84. Not that it matters anyway, GM flip flopped on the fluids they used in them. Internally they're all identical.
Old Mar 14, 2006 | 09:59 AM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Did you guys read this is not for a transmission? Its for a rear end. Depends on your budget, but I'm not sure if the Torsen units need limited slip additive.
Old Mar 14, 2006 | 06:15 PM
Dialed_In's Avatar
Sure did. Did you read the rest of the thread? Try and keep up
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
