What other stock tq converters will give me a gain?
Old Mar 13, 2006 | 06:33 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
I'm wondering what other GM cars have torque converters that the 700r4 can use to get some gains in acceleration and 1/4 times. I've read that C4 vettes have a nice 2500? stall and that S10 trucks have a nice 2200 stall. Is this correct?
What would be a downfall of installing one of these? Will the gains be worth it?
Old Mar 13, 2006 | 08:17 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i've used the stock converter off a 1998 S10 with the 4.3L it was a 2200 stall, I believe the corvette ones are the same, although the S10 one is cheaper than the corvette ones, probably for the name alone. There's no downfalls for a 1000 extra stall speed for $140 with lifetime warranty from autozone, give them your stock one as a core too.
Old Mar 13, 2006 | 08:33 PM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
I've got a 1991 GTA, is my tranny a 700r4? I'm interested in changing my stall converter as well. Although, I'm leary of Autozone parts.
Old Mar 13, 2006 | 08:45 PM
Car: 1994 Trans Am
Thanks for the info Xpndbl, did you notice a nice gain from them, sotp and 1/4? How did you launching get affected?
Thanks again.
-Kevin
Old Mar 13, 2006 | 08:54 PM
xpndbl3's Avatar
Car: 1984 Z28
yea definately launched a lot harder with that extra stall, was worth .3 in quarter mile times but then again the car was in the 14s at that time.
Old Mar 13, 2006 | 09:08 PM
Car: 1994 Trans Am
What were your 60fts like before and after, or are you a pretty decent launcher? Did it improve mph too?
Old Mar 13, 2006 | 09:15 PM
xpndbl3's Avatar
Car: 1984 Z28
i had that converter in the car years ago, i don't remember the times. New combo is a decent launcher though
Old Mar 14, 2006 | 04:38 PM
Justin86camaro's Avatar
Car: 86 Camaro
Engine: 350, aluminum heads, carb
Transmission: TH-700R4
Axle/Gears: 7.5 10 bolt, 3.42:1
converters
hey i've heard different things about torque converters i was hopin yall could help me out with. both are auto techs.. one says if your converter has a 2200 rpm stall the car wont move until it meets that and the other says its what the motor will stall out at (or not rev higher) unless the car is moving. and if thats right which makes alot more sense, would there be an advantage if i can spin the tires at a stop with my 215 tires?
Old Mar 14, 2006 | 05:05 PM
caribbean 85's Avatar
Car: 1985 Berlinetta (drag only)
Engine: 383ci chevy
Transmission: TH-350 T-brake
Axle/Gears: 9 inch Ford & 4.56 gears
Although both ideas in prinicple interpret what a torque converter does, the effect of the operation of a torque convertor in practical application will not cause the engine to stall or the car not to move "at all" until the stall rpm is reached
It just simply means that the EFFECTIVE engagement of the torque convertor is complete by the engine rpm increasing to the rated stall speeed of the convertor
So, a slightly larger cam that needs to be slightly higher in rpm before delivering full potential to the engine output will be complemented by a higher stall convertor which = both engine and convertor will reach their peak potential at the elevated rpm and the energy will be transferred to the momentum of the car
whew!!!!
Tech guys - feel free to chime in if this isnt as clear as is should be
Old Mar 14, 2006 | 06:30 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
is there any 60 degree v6 torque converters that have a higher stall then my firebirds?
jaridjohn
Jul 8, 2024 03:49 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
draco
Oct 4, 2015 09:25 PM
InfinityShade
Aug 22, 2015 08:00 PM
