what are the 3 wires that plug in the trans for
Car: 1984 z28 camaro / 2019 accord sport
those wires are the only wires holding me back from removing the main computer harness and was wondering what they where.
i believe they are the converter lock up wires but i am not sure
Transmission: 4L80E/4L80E
Two are for the converter lock-up. The 3rd is a 4th gear indicator - tells the computer when the transmission is in overdrive.
You need to keep the torque converter lockup functioning. The tranny won't remain happy if you cruise without it.
You can use a manual switch to provide the function. There's a tech article about it.
Car: 89 gta ws6, Dodge Turbo Diesel, H-D
Engine: 383 4-bolt #638 block
Transmission: 700r4, corvette servo, 2200 stall
Axle/Gears: 3.27 9 bolt b-w, pbr discs
5.7 is correct trans doesn't like it. If your already working on the thing pull the trany pan off and change the filter, while your there you will see the three 3 wires, 2 go forward to the lockup solenoid and 1 splits off 4"to6" from the plug and goes to the rear of trans to a pressure switch. Then you can see what goes where to do your lockup switch. good luck
i found this pic on the internet now all i need to know what color is A B and D
http://www.purplesagetradingpost.com...o/700R4p1.html
second to last pic
second to last pic
in the Pic A is purple, B is tan with a black line, and D is light blue.
the switch works great
some one can wight up a technicel article if they want
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Where is thsi article?
Chris
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
Chris
Chris
heres the link
https://www.thirdgen.org/torqueswitch
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Saw that, but I am wondering about best way to lock up the TC with no computer in the car at all.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The method in the tech article still works without a computer, as long as the wiring hasn't been hacked up.
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Originally Posted by z28z34man
my method will work with the harness hacked up see my pic
With your method it will auto lock in 2nd third and 4th correct?
with the switch in the down position it will lock in 2nd 3ed and 4th with it in the up position it will lock just in 4th. i also ran the ground threw the cruse break switch.
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
Sorry to hijack the tread, but as i was reading through this, i reallized, hey, my 200-c tranny has a 3 prong connenter with 3 wires going to it.. now it being a 3 speed auto tranny with no override what is the 3rd wire going to? (2 to the tourqe coverter lockup, 3 wire is for???) thanks guys.. just wondering on this one.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
ok i have nev3r heard of a dpdt switch
what is one and do you have a pic and can you get one at oreilly auto or napa or auto zone ?
thanks!
thanks!
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
