Calabrating the speedo gear
Old Mar 19, 2006 | 03:32 PM
84silverbirdSE's Avatar
Car: '79 T/A and '84 T/A
Engine: 455 buick and 305 chevy
Transmission: TH400 and T-5
I have an 84 firebird s/e with a 305 5-speed,2:90 first gear, 3:73 non-posi rear and an 85mph speedo. About a year ago i had to chang the tranny because i was having problems with it and the only tranny i could get quick to replace it was out of an 89 formula 5-speed, thats the only info i have from the donor car. My old tranny had a mechanical speedodometer while the donor tranny from the 89 had an electric.. So i couldnt swap out the speedo gears. Now my speedo reads about 20-25mph to much (e.g. driving 30mph speedo reads about 60mph).
My question is, does anyone know how to calabrate this new set up so i can figure out what speedo gear i need? Or know the ratio of and 89 t-5 out of a formula?
New set up:
85 mph speed-o
T-5 out of an 89 Fromula
3:73 rear. Thanks~Vinny
Old Mar 19, 2006 | 04:44 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes you can swap out the speedo gears. The speedo gears from your 84 non-world class tranny and the 89 world class transmission are interchangeable. Whatever speedo gears you had in your old tranny, put both of them in your new tranny.
An 89 manual trans car would have either 3.08 rear end or 3.45 rear end.
Old Mar 19, 2006 | 05:08 PM
Kev, I tried that, trust me. That was my first move.
The housing for the mechanical and electric speedo's were diffrent and the gears wouldnt swap.
Old Mar 19, 2006 | 08:17 PM
Kevin91Z's Avatar
I find that amazing. Are you sure its a T5? I've swapped speedo gears between NWC and WC T5's, and from cable and electronic speedos several times.
Old Mar 19, 2006 | 08:36 PM
Yes, mine was an orginal 1984 T-5. As for the other, the info i provided is all i know. I used to have an 88 formula and the new T-5 looked just like the one in my 88. I know, i dont understand why they wouldnt swap. I cant remember exactly because it was a long time ago when i did the swap and someone stole my old orginal T-5 so i cant go back and look. even if they did swap, the speedo's are diffrent.
Thanks ~Vinny
Old Mar 20, 2006 | 08:44 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I think I have what you need for the speedometer (cable driven) what is your e-mail? I will send pictures of what you need
Old Mar 20, 2006 | 03:48 PM
My email is xvin99@aol.com
Thanks for your help but Just so you know my speedo is hooked up and working. My problem is that i have the wrong speedo gear. Let me see the pic though. Thanks ~Vinny
Old Mar 20, 2006 | 09:55 PM
Engine: ls1, LB9
I hope the picture I sent of the gears helps... I did not send a picture of the sender (bullet looking thing in the trans) because you said yours was working and I assume you would already have this then. just the wrong gear
Old Mar 21, 2006 | 05:48 PM
hey thanks for the picture but it was very blurry. The first one on the left, cable gear, is the one i have, same color as well. Im not sure about the other one though. i never checked. In fact, i didnt know that i would have to chang that one as well. I thought i would just have to find the right gear for the speedo.
Thanks ~Vinny
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
88rscamar0
Sep 23, 2015 09:08 PM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
