Hey guys,
I don't know about you but I have never owned a automatic trans that has not leaked. I just got mine rebuilt by a professional trans shop and it still leaks. Who has some tricks for stopping this problem?
Thanks in advance!
Justin
Thanks in advance!
Justin
i'd take it back to the trans shop and have them fix the leaks, as for my camaro, I just put a rubber mat with some towels over it under the camaro, since it leaks maybe 1/4 quart a month.
lol exactly. There has to be some way to keep these damn things from leaking!
Thanks in advance!
Justin
Check the gasket/O-ring on the TV cable. I forgot to put mine back in after I rebuilt it and the tranny would leak 3-4 quarts all over the ground after it was shut off. I would fill it back up and no leaks while running. Shut it off, and it was the Exxon Valdez all over again.Originally Posted by eXesiv|83ta
Hey guys,I don't know about you but I have never owned a automatic trans that has not leaked. I just got mine rebuilt by a professional trans shop and it still leaks. Who has some tricks for stopping this problem?
Thanks in advance!
Justin
thats not the problem. I should have clarified. The problem is with the pan gasket sealing.
If it was on real good, they might (or someone previously) may have bent the pan in getting it off.
If that's the case it might be a new $30 pan to take care of that problem....
Tobias05
close
how about burning a whole in the speedo cable, and having that leaking? lol i did that a while back. buddy told me the gear might not be seated, and centrifigual force was pulling fluid up the cable to the hole.
pulled the housing and reinstalled it, hasn't leaked since.
i also had a problem w/ my dipstick, that was a horrible mess. took it out and bent the bracket back, and then added about half a pound of rtv on the o ring and the tube and everything in between. that stopped leaking too, lol.
i know how you feel...
If it has one of those cork gaskets replace it with one of the rubber/neoprene not sure if thats how you spell it. I could never get the cork to seal, but the rubber one works great. I think the one i just bought from advance is made by pro king.
ok thx. I was wondering if they did make them. I haven't been able to find a rubber/neoprene gasket. I will check them out.
Tobias05
close
Quote:
I also just installed one of those on saturday. no leaks!Originally Posted by MikeH
If it has one of those cork gaskets replace it with one of the rubber/neoprene not sure if thats how you spell it. I could never get the cork to seal, but the rubber one works great. I think the one i just bought from advance is made by pro king. haha, I think i may be subconsciously stalking this thread or something, lol.
Quote:
THANK YOU FOR POSTING THISOriginally Posted by my3rdgen
Check the gasket/O-ring on the TV cable. I forgot to put mine back in after I rebuilt it and the tranny would leak 3-4 quarts all over the ground after it was shut off. I would fill it back up and no leaks while running. Shut it off, and it was the Exxon Valdez all over again. Mine is doing the EXACT same thing... now I know what the hell is going on now.
not really tricks just good assembly pratices. flaten out the bolt holes in the pan. i like something ( like high tack or rtv)to stick the gasket to the pan so it doesn't shift when i install the pan. don't over tighten the pan bolts. never install a seal dry. make sure the o ring doesn't get cut installing the dip stick.
sorry but im pretty sure on the tranny pan you are suppose to put it on dry
TTOP350
close
- Join DateOct 2001
- LocationIl
- iTrader Positive Feedback100
- iTrader Feedback Score(9)
- Car1989-92 FORMULA350 305 92 Hawkclone
- Engine4++,350 & 305 CIs
- Transmission700R4 4800 vig 18th700R4 t56 ZF6 T5
- Axle/Gears3.70 9"ford alum chunk,dana44,9bolt
- Liked:1,156 Times in 755 Posts
The newer 4L60E trans has a reuseable gasket that works on the 700R4
Get yours now at a GM dealer!!!!!
If you ever have the tranny out, replace the pump to torque converter seal and the tail shaft bearing and seal. Got done installing a tranny and forgot to install a new pump seal and i had to deal with a tranny leak for about a year. probably why the thing went out on me too.
Quote:
the front and rear main seals (which you are describing) leaking would not cause a trans to fail unless you consistantly ran it low on fluid (forgot to check it and fill consistanly).Originally Posted by ace16a
