HSR with 700r4
Old Mar 21, 2006 | 01:55 AM
BADASS91B4C's Avatar
Car: 1991 B4C, 1992 RS
Engine: 355, 305
Transmission: 700r4, 700r4
Axle/Gears: 3.73, ?
HSR with 700r4
i just installed a holley stealth ram with a nitrous plate and now my TV cable has to stretch really really far to fit the t.b. (like all the way adjusted out) any one esle have this problem?
Old Mar 21, 2006 | 03:24 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
what did you start with for induction?
the TV cable comes in three different lengths. the Carb. the TBI, and the TPI all have diffent length TV cables.
Old Mar 21, 2006 | 03:31 AM
Engine: 355, 305
Axle/Gears: 3.73, ?
i started out with tpi but i used the TV cable that came with my hughes performance tranny, maybe i should get a new cable from GM?
Old Mar 21, 2006 | 04:51 AM
you may need to do that.. get one that you know is indeed long enough for the stealth ram.. the TPI one is the longest one... probably the one you would need i think
Old Mar 22, 2006 | 03:26 AM
Engine: 355, 305
Axle/Gears: 3.73, ?
i will do that thanks for the help
Old Mar 22, 2006 | 11:31 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
From what your saying the length of your TV cable isn't the problem, it's the adjustment and this HAS to be correct. Did you get the throttle linkage extension with your nitrous plate? If not you MUST have it, it's part number 1700NOS from NOS. I ordered mine from Auto Zone, it was like 20 bucks.
Old Mar 23, 2006 | 02:06 AM
Engine: 355, 305
Axle/Gears: 3.73, ?
thanks i will look into that
I looked that part number up on www.summitracing.com and nothing came up? weird
Last edited by BADASS91B4C; Mar 23, 2006 at 02:09 AM. Reason: Automerged Doublepost
Old Mar 23, 2006 | 08:02 PM
I found the part number in the instruction manual from my NOS 5050 kit and called Auto Zone, after haggling with them a bit they finally found it and 3 days later I had it complete with bolts and all. Good luck with it man.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
