How to install throw out bearing in clutch fork? (PIC)
Car: 83 recaro, 82 grandprix, 72 skylark
The throw out bearing has a bump in the ridge where the clutch fork rides in. what is it for and does that have to be installed a certian way? it is only on the one side.
It doesn't really matter where that goes. All it does, is keep the bearing from spinning on the fork.
What's more important is the little flat spring with the 2 ears that's attached to the fork. It goes ENTIRELY INSIDE the groove of the bearing; that is, the ears DO NOT "clip" onto the bearing, such that they are "outside" the groove. If you put it together wrong, the clutch will not release.
red90IROCls1
Aug 25, 2015 06:56 AM
db057
Aug 11, 2015 10:11 PM
rsrmoore
Aug 7, 2015 08:44 PM
