drive shaft removal
Old Mar 24, 2006 | 05:24 PM
kaptinkafeen's Avatar
drive shaft removal
Just wondering what is going on..
WCT5 trans,
as I attempt to pull the drive shaft out, I get trans fluid leaking out from the tailshaft of the trans...
There is nothing in the GM shop manual that suggests fluid will drip from the trans when the ds is pulled?
What's going on here? Any info would be appreciated.
TIA
-Andrew
Old Mar 24, 2006 | 06:05 PM
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
it happens
normal. It will like a little fluid out esp if you have the front higher than the rear.
Old Mar 24, 2006 | 06:16 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
I just pulled my drive shaft out yesterday. It leaked lots of transmission lube when I pulled the yoke out. It must be normal.
Old Mar 24, 2006 | 06:27 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
It's normal. Do not worry, but do not forget to replace the lost fluid.
Old Mar 24, 2006 | 07:23 PM
Borsty's Avatar
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
if it really bothers you pick up an extra yoke to put in there from a junkyard
Old Mar 24, 2006 | 07:26 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
as normal as normal can be.
Old Mar 24, 2006 | 08:01 PM
Great to hear guys - many thanks
It just floors me when after reading and re-reading the unexpected happens... I'm sure you guys know what I mean At least this time I kept my cool and didn't throw, punch, kick or even curse the car
-Andrew
Old Mar 24, 2006 | 09:29 PM
91banditt2's Avatar
Engine: 5.7 HSR
farther more one of these can be helpful in cutting down how much fluid that you lose.this will plug right into the tail shaft.
http://www.menintools.com/lisle/trannyplug.html
Old Mar 26, 2006 | 03:50 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The right size Tylenol bottle works as a plug too!
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
jharrison5
Aug 19, 2015 05:53 PM
Ozz1967
Aug 16, 2015 10:23 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
