U-Joint Question??
Old Mar 24, 2006 | 09:23 PM
Gargamel's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.7
U-Joint Question??
I have an '87 GTA I recently picked up and hearing the infamous "clunk" I replaced both u-joints. Well the car is still making the "clunk" both while shifting from gears(auto,5.7, 9-bolt) and when the car shifts into 2nd gear??? Could the new joints have been defective???? Any help is greatly appreciated.
Old Mar 24, 2006 | 09:33 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
could be the tranny mount is worn or broken.
Old Mar 24, 2006 | 09:37 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
could be tranny mount, or excessive play in the rear end itself, my 10 bolt would clunk in my s10 before it went out on me. But it was clunking for 40,000 miles before it finally went.
Old Mar 25, 2006 | 01:07 PM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
Transmission: 700-r4
Gargamel:
Not to highjack, but i still havent figured out the search function on the new forum....
How did you get the rear U-joint out?? I ripped the nylon fill seals out and cant figure out how to remove the u joint to install the new one?
Old Mar 25, 2006 | 07:23 PM
Gargamel's Avatar
Engine: 5.7
Got them out with a blow torch. I have already replaced the trans mount with a Polyurethane one. Like I said it's weird and only on the 2-3 shift. Thanks for the replies I really appreciate the help.
Old Apr 11, 2006 | 07:56 PM
Jforce2409's Avatar
I have a similar problem with my car. 87 iroc. When I put it into drive it kind of clunks but when i throw it in reverse it really clunks bad. Thought it might be the u-joints but they look fine and have no play. I watched the drivetrain and the drive shaft gets almost a full 3/4 turn when it gets put into gear (more turn for reverse than drive). I didn't see the tranny move but I might of missed it.
For the u-joints there is usually a clip on the outsides, if you don't remove the clip you'll have a REAL hard time taking them out. Like the other guy said heat is always a good way or an actual torch to cut them out.
Old Apr 11, 2006 | 08:09 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Check the motor mounts if tranny mount is good - I had a clunk that turned out to be a bad motor mount.
Old Apr 12, 2006 | 02:11 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
A clunk during the 2-3 shift is bad. If as you posted it is only the 2-3 shift then the shift timing is off. This is causing the trans to bind for a moment which unloads the drive shaft and rear gears. When the bind ends (as the 2/4 band is pushed off) the unloaded parts then reload with a clunk.
RBob.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
