Transmission swap heeeellllpppp!
Old Apr 4, 2006 | 06:00 AM
The Phantom's Avatar
Ok, this is my first day as a member of this site, and I have a question!
I have an 85 Z 28 that is now being converted to a 5spd from an automatic. The Tech artical is a great resource though I due require one additional bit of information. What is the measurement of the location for the shifter hole?
My car is in about 5000 pieces and I do not have the motor and tranny mated at this time, if someone has a 5 spd car that could measure the location using a common reference point, or a picture with a tape measure would be nice.
Thank you,
Dave.
Old Apr 4, 2006 | 08:34 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Try the transmission and drivetrain board. This board section is more for problems and comments directly about TGO.
Old Apr 4, 2006 | 09:49 AM
Board change.
Thank you I have re-directed the request.
Old Apr 4, 2006 | 07:41 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
As per the tech article you are reading (direct quote):
When the tranny is seated, install the 4 retaining bolts. Jack tranny & mark center hump where the shifter will protrude. You will need to cut a hole here. I used the dimensions that I found in the boneyard cars, 6 1/4" X 7 1/2". The center console, E-brake arm, & shifter need to be removed at this point.
OH!!!! You need to know WHERE to cut the 6 1/4 x 7 1/2" hole....
I think if you put it in the center of the 4 holes that used to mount your auto shifter it would be very close.
Old Apr 4, 2006 | 09:15 PM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
i cut mine only half an inch off or so and it kinda annoys the upper shift boot now heh.. no biggie but if you want a real good cut id wait till your installing it, make a hole big enough to install the shifter, slide the top boot on and use that as your guide
the hole starts about 1 1/2" from that dip in the tranny tunnel
Old Apr 5, 2006 | 05:27 AM
Thanks guys, bob I do understand the size of the whole, I am trying to locate and cut it now, as I have the interior out. See attached.
Old Apr 5, 2006 | 05:37 AM
Thanks guys, bob I do understand the size of the whole, I am trying to locate and cut it now, as I have the interior out. See attached, its much cleaner now!
Last edited by The Phantom; Apr 5, 2006 at 05:39 AM. Reason: Automerged Doublepost
Old Apr 5, 2006 | 05:47 AM
... and then I saw the rest of your reply bob, so if I center it to the middle of the automatic shifter mounting point you feel that should do it??? I have the lower boot for the holes diamentions, I would just prefer to make the mess now than later.
dr, I will see if that works with your information.
Thanx guys
Old Apr 5, 2006 | 08:14 AM
Greg '85 T/A's Avatar
Car: 1985 Trans Am/WS6
Engine: 5.0 TPI
Here ya go -
http://www.tacreationsusa.com/shift_boots.htm
Old Apr 5, 2006 | 10:09 AM
Engine: 383 SBC
When you make your cuts I would radius the corners if possible just like in the link pictures. That should reduce the stress put on the sheet metal at the corners.
Old Apr 5, 2006 | 10:15 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Holy crap dude, your cars gutted!
Looks like your going to have some fun putting it all back together
Old Apr 5, 2006 | 11:14 AM
... and believe me I say that every time I go into the garage! LOL
Did I mention it is a single car garage, for those that say it can't be done, it can but there are days when I could use an extra 5' on the width.
Old Apr 5, 2006 | 11:17 AM
Thank you for the pictures, they have helped, and if I need to weld one in I know where to find it!
As turd said, I will try radiusing the existing metal first.
AussiePr0nCar
Mar 6, 2020 04:04 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
gta90
Sep 15, 2015 04:00 PM
E Rod
Aug 28, 2015 05:17 AM
mizz0313
Aug 12, 2015 06:45 AM
