Shift Kit
Old Apr 12, 2006 | 09:08 PM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
Shift Kit
I'd like to get a shift it into my 88 with a TH350. I'm not looking for anything major just not these crappy stock gears. http://store.summitracing.com/partdetail.asp?autofilter=1∂=HUU%2D2858601&N=4294920458+4294904013+115&autoview=sku
This Hurst kit sounded good, any suggestions?
Old Apr 12, 2006 | 09:44 PM
r0nin89's Avatar
Gotta be the easiest trans-related question...
Old Apr 12, 2006 | 10:41 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
looks ok for a basic shift upgrade.
Old Apr 12, 2006 | 10:46 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Got a hurst kit in mine, did it out in the driveway and only took a few hours (including beer breaks!)
My 1-2 shift is awesome, barks the tires all the time (can be a bit scary when its slippery out!) the 2-3 doesnt seem much if any different though.
But its probably going to be alot different with your gears, im running 4.11s...
Old Apr 12, 2006 | 11:31 PM
r0nin89's Avatar
What does the rear end gear numbers mean? Like low numbers = ? Higher Numbers = ?
Also I have done some research and found that Transgo seems to be the best shift kit in alot of opinions. Any comments?
Old Apr 12, 2006 | 11:49 PM
Pro Built Automatics's Avatar
You do not want a "valve body" kit that breaks the tires loose at light to medium throttle. This is just HARD on the internals of the transmission, besides being dangerous. Trans-Go offers the best in terms of smoothness & firmness.
Old Apr 12, 2006 | 11:51 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Heard alot of good stuff abut the transgo kits but have never installed or driven a vehicle with one in it...
As for the gears, The numerically higher the gear ratio the lower the gear is and visa versa.
So 4.11s= all bottom end power
2.73s= all top end speed
Old Apr 13, 2006 | 09:16 AM
r0nin89's Avatar
Old Apr 13, 2006 | 09:38 AM
r0nin89's Avatar
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
