Cleaning the internals - solvent?
Old Apr 14, 2006 | 10:17 AM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
What is a good solvent to use to clean the internal parts up? Theres no real residue or buildup on anything so far, I just want to run them through to degrease them before I start putting everything back together. Only thing I can think of that I wouldn't mind using in the garage is Super Clean, but I honestly don't think it'll handle the job, and I'd be worried about rust since its mostly water.
Anyone use one of those $20 3.5gallon parts recirculating parts washers? If so what do you put in it?
Old Apr 14, 2006 | 10:36 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
diesel fuel is typically ran through the parts washers
Old Apr 14, 2006 | 11:09 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
I use kerosene. Then after cleaning, I spray they down with brake clean.
Old Apr 16, 2006 | 05:40 PM
w1964bgta's Avatar
Car: 89 gta ws6, Dodge Turbo Diesel, H-D
Engine: 383 4-bolt #638 block
Transmission: 700r4, corvette servo, 2200 stall
Axle/Gears: 3.27 9 bolt b-w, pbr discs
mineral spirits in my parts washer, a little easier on the skin but have used diesel fuel.
Old Apr 16, 2006 | 08:14 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
We use mineral spirits in our parts washer at school, but I go the extra mile to use brake cleaner on top of it. It's probably not a big deal to worry about, unless you're working in a dirty environment.
Old Apr 17, 2006 | 01:40 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I use parts washing solvent in my parts washer.... figured that's the "right stuff" for it.
Castrol super clean is the best non petroluem based degreaser i've ever seen though, beats the pants off simple green and others like that.
Old Apr 17, 2006 | 01:46 PM
I usually use diesel fuel, followed by lacquer thinner.
gta892000
Aug 11, 2019 11:16 AM
sailtexas186548
Feb 17, 2017 03:07 PM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
sreZ28
Oct 22, 2015 08:21 AM
scottmoyer
Sep 7, 2015 07:06 PM
