opinions on a rearend please
Old Apr 14, 2006 | 03:10 PM
wstdintllgnce's Avatar
Car: 91 RS, 92 z28, 02 SS
Engine: 305 TBI , 350 TPI, LS1
Transmission: 700R4, 700R4, 6-speed Manual
ok...so i want to set my car up for more than just straight line running...and i'm almost leaning towards drifting with it...but i think i'd rather handle well through corners than slide....so what are your recommendations on gearing? and should i go with a limited slip...or full posi? any opinion would be helpful in swaying my decision.
Old Apr 14, 2006 | 03:27 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Limited slip and posi are the same thing.
Old Apr 14, 2006 | 03:39 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
thanks for the info but you know what he meant do the one legger or the true posi
Old Apr 14, 2006 | 03:41 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Could be, or maybe he meant posi or a spool. Hard to tell.
Old Apr 14, 2006 | 10:07 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
what is spool?
Old Apr 14, 2006 | 10:11 PM
89TransAmWS6's Avatar
Car: 1989 Trans Am WS6
Engine: 305 5.0L 171RWHP, 263 RWT
A spool keeps both wheels locked at all times, where as a posi only locks up under load
Old Apr 15, 2006 | 11:48 AM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
4 terms, let's not confuse the poor guy.
1. Open diff. one wheel wonder, bad for traction
2. Posi(limited slip). Used in most factory posi aplications. Uses clutches and friction to lock the wheels together, but allows slipage in corners(to compensate for different wheel speeds). Great for general performance use. Probably the best choice for your car.
3. Locker(like a Detroit Locker) Mechanically locks the wheels together under load by engaging teeth with one another with no slipage between the two. Unlock soff load. can make corners "interesting" if you're on and off the power because of the harsh engagment. They also "ratchet" or "clunk" in corners. Super strong with excellent straight line traction, but probably not what you want.
4. Spool. Mechanically locks the axles together 100% of the time. great for straight lines, very very bad for corners. relitivly unsave and unpredictable in the rain, snow, or any other time changing traction conditions are present. Don't get a spool.
Old Apr 16, 2006 | 08:14 AM
Car: 1988 SC Camaro
Engine: 305 TBI
Thanks! That was very helpful
Old Apr 18, 2006 | 09:38 AM
sorry bout that..i confused myself...i seem to have a problem with the posi-limited thing....but yeah...i meant full lock or limited....seems to me the car is open diff right now....so a locker would be better for drifting where the limited would be better for cornering.....it's for the rs...and i think i may go drift with it....i have the z and the ss for cornering....so should i go with the lock then? or would you still say limited?
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Oct 5, 2015 06:23 PM
Jlanz55
Sep 29, 2015 08:55 AM
