v6 t5 with v8
Old Apr 19, 2006 | 06:42 PM
pyro719juggalo's Avatar
Car: 1989 RS
Transmission: t5
Axle/Gears: 373 locker
v6 t5 with v8
I just discovered that my tranny is actually a v6 tranny with coarse spline input shaft I have already ordered a new clutch only to find out the friction disc wont slide on the input shaft! Can I just buy a v6 friction disc and slap it in?
Old Apr 19, 2006 | 10:25 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
dude i did the same thing not knowing and bout screwed up my trans tightening it too tight a few years earlier.....i dont know about buying a new pressure plate...I think the pilot bushing hole is differant size but dont take my word for it...maby someone can help more than me....all i know is i had to pull my trans 3 times before getting it right...that sucked
Old Apr 20, 2006 | 08:03 AM
BigDreams92's Avatar
Car: 1992 RS
Engine: Vortec Headed 383 9.6:1
Transmission: TKO600
Axle/Gears: 10 Bolt Posi 3.73
yes, but holding power and longevity of the disk will be compromised.
Old Apr 20, 2006 | 10:50 AM
Car: 1989 RS
Transmission: t5
is there a disc I can buy that wil go right in? its 10.4 dia with 14 spline I read on another messageboard that a astro van with a 5 speed might work? Any help would help alot thanks.
Old Apr 20, 2006 | 11:16 AM
Car: 1992 RS
Is it 14spline? I thought v6 3rd gen t5's was 15spline....
Was the car an original v6 and that's why you have a v6 T5?
If it was an original V6 car with T5, and you just need something to get you back on the road, a v6 clutch disk will *work. You can purchase one from any major autoparts store, just when they ask you what motor is in it say v6 instead of v8.
They may make an aftermarket disk that has the v6 spline count with the larger diameter disk, I don't know, I haven't looked. If the v6 trans is something you will be keeping long term a more permanent solution than a v6 disk should be found though. It may be possible for a machine shop to swap out the center section of the disk as well.
*work can be taken many different ways. Like previously stated using a v6 clutch disk can have adverse affects on performance and should not be used if it can be avoided. The V6 T5 utilizes a clutch disk much smaller (diameter) than the V8 T5 because of what it originally mated to. This is where your holding power takes a hit, under heavy load slippage will become an issue. The other concern is that the added stress of the V8 on the V6 clutch disk will wear the disk out much faster than it would in a V6.
Old Apr 20, 2006 | 12:36 PM
Car: 1989 RS
Transmission: t5
I found a clutch disc that will work its from a 83 s10 9 11/16 dia with 14 spline only a half inch smaller than OE
Old Apr 20, 2006 | 01:19 PM
Car: 1989 RS
Transmission: t5
anyone know how much to cut off of the input shaft?
Old Apr 20, 2006 | 01:43 PM
Car: 1992 RS
Good info about the clutch disk, I didn't realize that. Of-course I never really looked either, didn't want to give myself an excuse to stick with the T5.
As far as cutting the input shaft goes, I've heard anything from .25" to .5" I didn't have to cut mine at all though, so I'm not sure what's going on there. Mine bolted up fine and everything spins freely like it should.
Old Apr 23, 2006 | 05:47 AM
Pat Hall's Avatar
The V8 input shaft is 8 and 3/4" long, the V6 one is 9 and 1/4". So you have to trim off 1/2" from the pilot bushing area. Qytum has a post on here on how to go about it. Here's a link. www.qytum.net/tech/t5info
t5, v6, v8
