What gear's do i need?
Old Apr 20, 2006 | 06:46 PM
19kilo's Avatar
Car: 1985 Z-28 2003 chevy Silverado Z71
Engine: was 305 LG4 now 355 HO
Transmission: TH700r4
Axle/Gears: posi 373
1985 Z-28 with the 308's posi i want 373 what do i neeed?
Old Apr 21, 2006 | 01:09 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
UPDATE: thread was moved to trans board, ingore this post.
try the transmission board. to answer ur question, i dont know, but let me know wen u find out. i hav 2.73 and want to go to 3.73.
Old Apr 21, 2006 | 01:57 PM
teapot3208's Avatar
Car: 1985 Camaro
Engine: 350 .030 over (355)
Transmission: 700-R4
I'm pretty sure you'll need to get gears made for a 2-series carrier...that and, well, the install kit.
Old Apr 21, 2006 | 02:23 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
if you wanna go with gears lower than a 3.08 ratio, you have to get a 3-series carrier. You "might" be able to find 3.42's or 3.73's for 2-series carriers but don't count on it..thats very rare.
Old Apr 21, 2006 | 04:29 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Richmond gears makes them for both right?
Old Apr 21, 2006 | 04:33 PM
I think they do but are a little more $$ than the 3-series ones though...if you're looking for better performance traction wise, just get the 3-series carrier and you'll have a much wider gear selection and no more peg leg rear.
Old Apr 21, 2006 | 04:44 PM
Engine: LB9, LB9
What car or rear end can I get a series 3 from that will accept my 28 splin axles btw?
Old Apr 21, 2006 | 04:52 PM
usually the '89 up irocs, GTA, Formulas (some '88 too) or if you could scuff one from a 4th gen rear, that would probably be the best find as those cars came with much improved 3-series carriers.
Old Apr 21, 2006 | 05:09 PM
Engine: LB9, LB9
Ok so any 4rth gen carrier is a series 3 and takes 28 splines? Also if it is a 2.77 (i think) posi from a IROC or something, that means it is a series 2 I take it?
Old Apr 22, 2006 | 10:49 AM
19kilo's Avatar
Thanks for the imput i have no idea what you guy's are talking about (3-series carrier ) i went on summit tryed to find what i need carrier gear's install kit but i dont want to order the wrong parts so my car has a 2 - series carrier right? Can some one list all the parts i'll need carrier,gear's,install kit so when i get to the shop its all there thank you!
Old Apr 22, 2006 | 05:18 PM
90camaro, if its one of the earlier irocs (85-86) with 2.77's most likely its a 2-series carrier.
Old Apr 22, 2006 | 05:30 PM
19kilo, I see you have an '85 Z28 so changing your carrier to a 3-series one is a good idea in terms of you'll get WAY better traction as you'll have both rear wheels grabbing instead of one. As for the install kit, all you have to do is find a vendor (summit, jegs, ebay, randy's ring & pinion etc) and order a MASTER intallation kit for a 7.5" GM 10 bolt rear and that kit should have everything needed to install the gears and the carrier...the install kit usually doesn't come with gears and carrier though.
Old Apr 22, 2006 | 06:59 PM
Engine: LB9, LB9
All 350 TPI cars had posi in them right? My friend has a 1989 iroc 350 tpi and I thought it was posi, meaning which gears does it have? Thanks guys im starting to understand.
Old Apr 22, 2006 | 07:05 PM
seem to me like you're getting confused because you are mixing up or don't know the meaning/difference of the terms "carrier" and "posi"....they are the same things.
Old Apr 22, 2006 | 10:28 PM
19kilo's Avatar
my car has 308 posi so that a 3 carrier right?
Old Apr 22, 2006 | 10:33 PM
still doesn't mean its a 3-series carrier, a lot of the earlier thirdgens has 2-series.
Old Apr 22, 2006 | 10:35 PM
19kilo's Avatar
ok so some 85 IROC-Z/Z-28 came with 277 slip some with 305 posi did any come with 3 carriers? How can i tell what i have?
Old Apr 22, 2006 | 10:39 PM
the irocs from about '87-90 has 3-series, do a short burnout then get out and look at the drag mark, if you only see a mark from one wheel, you have a 2-series carrier.
Old Apr 22, 2006 | 10:54 PM
19kilo's Avatar
I've done that to see if i had posi or not i saw 2 burn marks.
Old Apr 22, 2006 | 10:56 PM
if you weren't the first owner of the car it was probably swapped out by the original owner or any other owner it may have had.
Old Apr 22, 2006 | 10:58 PM
19kilo's Avatar
Dose it matter if u did it in revers?
Old Apr 22, 2006 | 11:01 PM
you DON'T want to do that.
Old Apr 22, 2006 | 11:04 PM
19kilo's Avatar
Let say i did and 2 black marks what is that?
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
