Pedal adjustment for better heel&toe?
Car: 1991 Firebird
Axle/Gears: 3.42 w/auburn racers diff
Hey i was just wondering if anyone has modified their Pedals in their car so that the brake and gas pedal are level with each other ( or at least closer). Trying to get my heel on the gas pedal while putting the brake on is really hard due to how much higher the brake pedal is when compared to the gas. Has anyone modified their pedal assembly for this reason? i have a 91 firebird with a T5.
Car: 92 Camaro RS
Transmission: T5 manual
I did last fall by ordering a set of Sparco bolt on pedals for $25. I removed the rubber covers off the car's pedals and drilled holes for the bols. I got them so close now that I work not to press the throttle pedal when pressing on the brake.
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
My brake pedal is far below the gas pedal when I'm hard on the brakes, has anyone else had that issue?
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
another thing I do is put the arch of my foot on the brake pedal and tap the throttle pedal with my toe. Seems to work ok for me.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I fabricated a bracket to the throttle pedal rod to relocate the plastic pedal up higher (farther away from firewall). It's just about even with the brake pedal now. The drawback is that it's quite high off the floor so I need to know exactly where it is. It's easy to move my foot to the right and miss the pedal or slide my foot under the pedel.
The reason I did the relocation is that I have my seat set back farther than stock and I had to fully reach with my leg to go to WOT. Moving the pedal backward has me in a more natural position and only moving the ankle is required to move the throttle.
I don't need the "heel/toe" thing. Left foot holds brake pedel until transbrake is set then brake pedel is released.
LT1Formula
Oct 8, 2015 08:34 PM
