Torque converter question
Old May 5, 2006 | 07:18 PM
vwaltdog's Avatar
Car: 87 Trans Am
Engine: now a 350
I was wondering if the torque converters changed from year to year. I just put a 700r4 from a 83 Firebird into my Trans Am which had a 87 700r4. I used my converter from the 87 and now the car stays in park no matter what gear I put it in. I also hear a sound that sounds like I have a blower on the engine. The sound seems to be coming from the front part of the transmission. When I bolted the flex plate to the TC I noticed that the TC moved foreword to meet the flex plate.
Old May 5, 2006 | 07:23 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The spline count on the input shaft changed between 83 and 84. The converter from the 87 won't work on your 83 transmission.
Old May 5, 2006 | 07:50 PM
vwaltdog's Avatar
Car: 87 Trans Am
Engine: now a 350
Ok I was afraid of that. Did I wreck anything by putting the wrong converter on?
Old May 5, 2006 | 08:04 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The splines on the input shaft or the converter might have taken a little damage, but I wouldn't really think so. You should be able to look and see when you take it apart again.
Old May 5, 2006 | 08:06 PM
vwaltdog's Avatar
Car: 87 Trans Am
Engine: now a 350
thank you for your help
Old May 5, 2006 | 09:18 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Ouch!
Thats weird how it would even all go together...
Old May 5, 2006 | 09:30 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
that sucks, know how you feel. at least you got some experience swapping parts around.
better luck next time!
Old May 5, 2006 | 10:02 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Originally Posted by 84z28350
Ouch!
Not that weird. There are fewer splines on the early ones because the input shafts are a smaller diameter. If he'd tried to put an early converter on a later transmission it wouldn't have gone together.
Old May 6, 2006 | 02:43 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
I guess that makes sense.
I imagine that thing spinning around on the input shaft at mach1 would be pretty hard on the splines!
Can he not just swap out the whole shaft? Or did gm decide they didnt want those to interchange?
Old May 6, 2006 | 03:53 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
By the time you've done that, you've torn the whole transmission down to get at it. Easier just to get a torque converter that fits.
Old May 8, 2006 | 07:16 PM
vwaltdog's Avatar
Car: 87 Trans Am
Engine: now a 350
Got the correct converter on now it runs great. No damage that I could see. I will never do that again!
Old May 8, 2006 | 08:33 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Awesome, good to see their was little-no damage!
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
69 Six Pack
Oct 5, 2015 07:51 PM
redmaroz
Aug 16, 2015 11:40 PM
gwade12
Aug 8, 2015 08:17 AM
