Dexron II or Dexron III...is it the same?
Old May 3, 2006 | 12:52 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I realized after the fact that I dumped Dex III in the Tranny. Od course the manual calls for II. Is III just an updated version that is compatible? Kinf of like DOT 3 and DOT 4 brake fluids are.
Old May 3, 2006 | 01:46 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
III replaced II
II is non existant anymore, been gone for a long *** time like a decade, or decade and a half
you worry too much
run your dextron and enjoy it
Old May 3, 2006 | 01:49 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Originally Posted by Fast68
you worry too much
Better than not asking questions and ending up with a burnt up tranny!
God knows the things are always on the edge of meltdown as it is!
Old May 3, 2006 | 08:20 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The newest oil is backward compatable. Anything that took Dexron II will now take Dextron III. You can even use the synthetic IV or V just don't mix them or at least you're not supposed to. All oils of the same grades are designed to be mixed as per industry standards.
Try finding an old tranny dipstick that just says Dexron. I think II came out in the early 70's. The original Dexron was the best however it also used Sperm whale oil as an additive and when whale hunting was banned, they needed to find a replacement. The first II wasn't very good and damaged the seals.
People also panic about engine oil. They're dipstick says to use SC oil but all they can find is SG (or newer). It's the same thing. The newer oils have replaced the older grade requirements.
jay173
Oct 9, 2010 09:07 AM
QuickStyle
Mar 11, 2007 08:34 PM
Chevmdnss
Oct 9, 2005 11:09 PM
Dr G
Aug 2, 2004 03:23 PM
91NiteRida'
Apr 26, 2004 04:47 PM
